Float height
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    I went through this whole deal with a nearly identical setup, but I had a Mac header with a cherry bomb grafted on it.
    I found that no matter what you do, it will always stumble a bit on the low end if you have a straight through exhaust. You said Jardine on yours, but has the baffle been drilled out or molested somehow?
    I was never able to get it all smoothed out, with the open exhaust. It would run like a scalded cat on the top end though. I put a Jardine spaghetti exhaust on it and the low end was much better and the top end suffered very little when jetted properly.
    Ich habe dich nicht gefragt.
      Originally posted by trbig
      Did the 81 have adjustable needles?
      Not exactly. They were not factory adjustable but I have heard/read of folks slipping an extra little washer in here and there to raise them up.
      • xs11widowmaker
        • Aug 2009
        • 50
        • wadsworth ohio
        I just put in 120 mains and lowerd the floats. got everything back together and now numbers 3 and 4 are not firing. what could this be? before the 120's i tried 110's and it was firing fine but it starved for gas as the rpms went up. im lost. somebody rescue me. thanks
        • Crazcnuk
          • 2980
          • Hinton, AB, Canada
          "They were not factory adjustable but I have heard/read of folks slipping an extra little washer in here and there to raise them up. "
          Many of the canadian models came with adjustable needles, even in 80-81 and. also, some of us have 80-81 with the upgraded needles from MikesXS which are adjustable.
          '05 ST1300
          • tarzan
            • 1700
            • Chandler,Az.
            Widowmaker,
            Do you have a fuel line kinked.Those two carbs(3&4) are linked.So maybe you arent getting fuel to them somehow.
            80 SG XS1100
            14 Victory Cross Country
            • xs11widowmaker
              • Aug 2009
              • 50
              • wadsworth ohio
              fuel is coming out of carb4. 1 and 2 is hot and 3 and 4 is much colder. my 1100 has turned into a 550 im really at my wits end. thanks for your help
                • 7830
                Just me, but I would put 115 mains, and 42.5 pilot jets in. The 3&4 NOT working IS fuel. check vents and fuel lines when the tank is ON. If you can't see for sure, pull it up and S-L-O-W-L-Y let the tank down, checking the fuel line as you do. If it's a Special, try running on "prime" and see if that helps.
                • xs11widowmaker
                  • Aug 2009
                  • 50
                  • wadsworth ohio
                  just got home from work. I will try it tomarrow and let you know. thanks for your help
