I have strong spark and the carbs should be clean enough to run, even if I have not yet done the second and third mandatory cleanings. The passages were clear enough for spray cleaner to get through. But still no start.
I'm thinking the timing could be way off. I just threw the timing plate on there from the parts bike. So how can I get the timing close enough to start so I can put my timing light on it? I was kind of hoping to do this without pulling the valve cover because I don't have a replacement gasket on hand. I will pull it if I have to, though.
Suggestions are welcome.
Patrick
Patrick
(Sold back to Maximan)
