So the issues drag on :)
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    Originally posted by joebus
    Wow thanks tarzan...Oh and how do you sync carbs when you cannot keep the bike from reving out of control? I can back the idle adjust screw out and it wont change a thing. There seems to be enough fuel going by looking at the lines.
    I use a spirit level type synch (cheap and easy to make, and very accurate). Its obvious which way you need to go before the engine even starts. Once it gets to where you can start it without the fluid rushing to one cylinder, it is very sensitive, to the point that the weight of the screwdriver on the screw will make an inch or so worth of difference.
    Ich habe dich nicht gefragt.
    • joebus
      • 104
      • Indianapolis
      I have seen a couple of times people getting their sync liquid sucked right into the bike. I will be ordering a Mechanical one today.
      1979 XS1100 SF
      1981 KZ440 bobber
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        Yeah, the last thing you need is a half ounce of ATF in each cylinder.
        • dbeardslee
          • 4385
          • Maineville, OH
          #34
          I doubt that would hurt it, but it sure would make it smoke. I treated my rings with Marvel Mystery Oil (which I'm pretty sure is nothing other than ATF) last fall. When I fired the old girl up she laid down a smoke screen that could have been used on Omaha Beach .
