Mysterious Black fluid coming out Pipes
  • Mysterious Black fluid coming out Pipes
    Well after thinking we had a dead cylinder on my boss Bobs bike, we put new plugs, wires, coils, and new carbs..... still doing the same. It Smokes and a real thick black fluid comes out of the pipes. Havent done a compression check on it but just need some Ideas from others on what it could be.
    Austin Ingalls
    MIDNIGHT FURY
    XJ maxim rear air shocks
    KERKER 4-into-1 exhaust
    Pod Filters
    Money pit.......
    BLACKED OUT
    Well, the only black fluid on these things is used oil. Have you looked at the plugs to see if they are getting oiled? A compression/leak down test might be in order.
      From personal experience... I pray for you that it's not oil. Wow what a nightmare I've had with that.
      If you don't own a fire extinguisher, do me a personal favor and go purchase one... immediately.
      1980 MNS
        If you're lucky, it's condensation dissolving the soot in the pipes. If you're not lucky, well, that's been covered above.
        Get some of the liquid on a finger and see if it's slippery like oil. Can't think of a better test than that.
          Sooty Stuff
          I've seen this happen when running a fan to keep engine from overheating during carb tuning.Remember you're in the deep south as well and humidity is baaaaad!! I wish you luck.
          78 XS1100E Standard
          Coca Cola Red
          Hooker Headers
          http://i408.photobucket.com/albums/p...m/DSC00580.jpg
          1979 XS1100 Special
          http://i408.photobucket.com/albums/p...m/DSC00612.jpg
          1980 XS Standard
          http://i408.photobucket.com/albums/p...m/DSC01137.jpg
          2006 Roadstar Warrior
          http://i408.photobucket.com/albums/p...um/warrior.jpg
            Run the compression check. That will tell you ALOT of things. Remember to open the throttle all the way up when you run the check!! IF a cylnder is low, add a bit of oil (two teaspoons) through the plug hole and try again, if the number goes up its rings. If one is basically no compression, well maybe you got Varnaed!
            If you are not getting the engine warm and repeatedly running it briefly, you will get black water out the pipes, mine tends to run out the crossover.
            If it is oily, well oil it is. Then, well, Hope for water.
              I've been turned into a verb... ouch.
              1980 MNS
