Well after thinking we had a dead cylinder on my boss Bobs bike, we put new plugs, wires, coils, and new carbs..... still doing the same. It Smokes and a real thick black fluid comes out of the pipes. Havent done a compression check on it but just need some Ideas from others on what it could be.
Mysterious Black fluid coming out Pipes
Well, the only black fluid on these things is used oil. Have you looked at the plugs to see if they are getting oiled? A compression/leak down test might be in order.1980 XS850SG - Sold
-H. Ford -
Sooty Stuff
I've seen this happen when running a fan to keep engine from overheating during carb tuning.Remember you're in the deep south as well and humidity is baaaaad!! I wish you luck.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
Run the compression check. That will tell you ALOT of things. Remember to open the throttle all the way up when you run the check!! IF a cylnder is low, add a bit of oil (two teaspoons) through the plug hole and try again, if the number goes up its rings. If one is basically no compression, well maybe you got Varnaed!
If you are not getting the engine warm and repeatedly running it briefly, you will get black water out the pipes, mine tends to run out the crossover.
If it is oily, well oil it is. Then, well, Hope for water.Life is what happens while your planning everything else!
78 XS750Comment
