I finally got my master apart today and it was pretty bad. The rubber was fine so I decided to clean it up and slap it back together. It was working before I cleared the whole system (all krunked up) So it should be working fine... Did I reassemble wrong?
Banjo/ Spring/ ]cup []Piston with ]cup/ Owasher/ Cspring clip
I have both cups facing the banjo ]<---- and the steel cap on the spring is set into the first rubber cup.
The gunk is UNDER the seal, and that is the #1 cause of caliper malfunction on these bikes. It may not be the cause of the current issue, but it needs to be done anyway, and is worth a shot.
not certain it's 100% clean but I plan on going back in and doing the job right once my master rebuild kits get here. I just needed to get 'er on the road.
