The bad news or good news is: yes, a stuck start button will hold the start solenoid engaged and it will keep the ignition and almost everything else powered up and running even if you turn off the ignition switch, pull all of the fuses or hit the kill switch.
If your start button is melted or broken that's probably what happened.
Regards,
Scott
Regards,
Scott
(Sold back to Maximan)
Beside the replacement spring's tip appearing smaller, the copper colored aftermarket spring also felt slightly weaker by comparison than an original spring when I squoze it as well .... not a scientific test though.
