Which valve stems do I need?
  • Incubus
    • 1003
    • Austin TX
    My new project XS came with tubeless rims. The PO, however, used tubeless tires. At least the double nuts around the valve stem look very much like tire tubes to me. I plan to run tubeless tires. Is the valve stem a standard automotive sizw that I can pick up at any auto parts store? Or is it a special size I have to get from my local Yamaha dealer? Or is it a special size I can get from an auto parts store?
    Thanks,
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • Silent
    • 343
    • San Jose, CA
    I can't answer your question directly, but when you find out the size I'd be interested to know as well. I have a set of 90 deg valve stems on the FJR and I defiantly want to put a set on the XS when I change the tires next time. I get them from BikeEffects Jeff's a good guy to deal with, but I doubt he would know the answer to this question either.
    Ray
    '07 FJR1300
      It's a part number 93900-00001-00. Standard Yamaha part.
      • Incubus
        • 1003
        • Austin TX
        That's, CB. That looks like a double nut setup to me. Maybe PO did run tubeless tires. Guess I won't know until I pull them off.
        So I'm guessing an automotive stem won't fit. Bummer.
        1969 Yamaha DT1B
          Just .02 to add... tubeless valve stem, both nuts should be on the outside of the rim. When using a tube, one nut on the inside of the rim, the other on the outside. Dennis Kirk also carries the proper tubeless valve stems.
