I have the head and cylinders off my XS.The chambers on the head were crusted with carbon and I couldn,t decide if the valves were good or not.I have not disassembled the head.The reason for disassembly was I couldnt get rid of the popping back through carb 1.Then I figured while I have the head off I should check the rings.
The bike has 40,000 miles on it and the cylinders are glazed with no ridge at all.
The bike did burn a little oil a little sometimes.Although I have on had this one running a total of 4 or 5 hours while trying to get it to run right.
Heres my plan,I bought a 81 head on ebay.Supposed to have 4000 miles on it.
All the exhaust valves are tan colored and look like it ran good.
Can I just put the cams from my '78 in these heads.I know I can,but is it plug and play?
I am going to hone the cylinders and clean all the ring grooves and pistons and reassemble.Will my old rings seat in do you think?I know I cant get stock rings,right?
