Cams
    Hey Pete...
    What the heck are you talking about?? Just saw the title and threw a post in?? lol..
      Hey Ivan,
      Perhaps you're shopping in the wrong places, OR are talking about some VERY LARGE types?? I have one similar to this that I got on Ebay,this is a NEW one from this company.....yeah, they are a CHINESE supplier!
      Horizontal and Vertical Rotary Table 6"
      Product Pricing
      Your Price: $239.00
      Product Code
      202-2001
      Note, it shows that one full crank of the handle is 4 degrees. On mine, I have to crank it 15 times to get 60 degrees...so that's the same....I had to get one to be able to mill out my SOFA's and such!
      My other question is would folks want/need to be able to rotate the sprockets in both directions to be able to either retard or advance the cam timing? I would think so. And as has been mentioned perhaps only 5 degrees of total advance AND total retard for an arc of 10 degrees??
      I'm not saying that I would be able/willing to do this..my equipment is just some cheap home style mill/lathe, all manual controls....no CNC stuff!!
        And then we're back to the talk of..(This was before I understood much of this) since we're talking 5 degrees...which is usually measured at the CRANK... would we really just need 2 1/2 degrees cut on the cam sprocket to equal 5 degrees? ( takes two turns at the crank to one cam turn). Or when they talk of advancing the cam 5 degrees.. are they talking about actual degrees on the cam sprocket.. which would be a 10 degree CRANK advancement.
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          Well, TC, if you already have an indexing table, you should be able to machine a spud that fits the center of the table and a shoulder that fits the center of the cam on a lathe. Then it would simply be a matter of centering the mill on one axis, say Y, then moving in X until the endmill aligns with the bolt hole in the sprocket, and mill the slot either side.
          IIRC cams are measured in degrees of crank rotation, so it would need to be machined half as much. Only 2.5 degrees either side of the original hole. I think that equates to 3/4 a turn of the handle.
          the problem with me buying even a cheap one, is that any bonehead in the shop has access to the mill and lots of them like to turn it on and crash it into the table and such because they would rather be texting or playing their PSP than working, and if the mill is shot, they can hide and do what ever. Lugging that thing back and forth to my tool box every night would be a pain.
          If we really get going, maybe we coudl design a spring loaded advance that will adjust the cam timing according to RPM. (not that I think this would ever work well...)
          Ich habe dich nicht gefragt.
          • Ivan
            • Jul 2008
            • 2524
            • Hutchinson KS
            Ok, I just lumbered out to the garage and checked out the set of cams I have out of the motor. There are 34 teeth on the sprocket, which makes each tooth about 10.5 degrees.
            The retaining bolts are so close to the centerline of the sprocket, getting enough of a slot to make a 5º change in cam timing would be easily done with a dremel and a stone. We're only talking about maybe 1/16 of an inch elongation.
            I may have to rethink the strategy and figure a way to drill another set of holes in the sprockets that would allow a neutral and a 5º advance and a 5º retarded setting. Lots of aftermarket V8 cams have three holes for the dowel pin, which does exactly the same thing.
            Maybe Mr. Hodges will chime in here..
              It's been awhile since I was into the engine that far, but I vaguely remember that there was a little play in the sprocket on the cam shoulder even with a bolt in place, so the bolt hole was already a little larger than the bolt which would allow a small amount of variance in it's position/degree. I don't recall any pin for positioning, since it uses 2 bolts to secure it. I think I remember on the old cars, they used a central mounting bolt, and so they used/needed a positioning pin!?
              I know when I've done the Dremmel gear fix, that I use a small stone for the slots, and it does a fairly quick job of it, so I think you're right in that folks could do this at home without a fancy mill and rotary table!
              • tarzan
                • 1700
                • Chandler,Az.
                I actually did fill the ports with water on my 78 head after I pulled it off the bike.All the valves held water.No leaks.So I think my old head is ok.I havent disassembled the head becuase the valve spring compressor I have for autombile engines is too big to get on the valves.
                Does anyone have an easy trick to disassemble an XS head?Or do I need a special valve spring compressor?
                I figur I will disassemble the head ,check the valve seats and relapp and new seals.
                80 SG XS1100
                14 Victory Cross Country
                  Use a 6" C-clamp and a piece of 3/4" PVC pipe to remove the valve springs. Cut out the "X" area to access the keepers.
                    Very simple solution
                    Hey Rick,
                    I was just over at dbeardslee's mancave this weekend and we were disassembling a head off an XS. He simply used one BFC (Big F....ing C-Clamp) and a pice of 3/4" PVC pipe with a "window" cut out of it. I think Biker Phil or some others have posted how to make one before. It was slicker than snail snot. Just make sure the window is turned the correct direction and tighten the clamp. The non-moving end of the clamp was on the head and the other end on the cap on the end of the PVC pipe piece. The keepers mostly fell right out of the valves and a magnet pulled them right out through the window, loosen the clamp and the springs and valve come right out.
                    I have a clamp that big, so if I should need to remove valves at some point, that PVC pipe is the trick in my opinion.
                    Dang Phil is quick. At least I gave him credit so I do not look like I was bogarting his idea!!
                    • tarzan
                      • 1700
                      • Chandler,Az.
                      Great idea.I have a couple big c-clamps and I might even have the PVC.
                      I'll try tomorrow.
                      Thanks guys.
                      Rick
                      80 SG XS1100
                      • petejw
                        • 2269
                        • sydney australia
                        Tod,
                        lol, Sorry, I read his post not the heading, didnt notice any reply to his valve question.
                        Tarzan,
                        Heres a pic of the clamp i used with a lawn mower plug socket welded
                        to the end and a cut out to get to the collets. This works great, is strong and allows
                        you to use both hands.
                        I originally used the pvc but found it bend and flex was ok for a cpl of valves.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        1981 xs1100 RH (aus) (5N5)
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                          Sounds like you were using regular PVC instead of the thicker schedule 40 stuff.
                          I have lots of extra parts, so I drilled the middle out of one of the shim buckets. (Not an easy task...that's some good steel) I just run the clamp down onto that bucket and the keepers come right out of the center hole. Not an option for everyone to do though.
                          • Ivan
                            • Jul 2008
                            • 2524
                            • Hutchinson KS
                            Pic? Sounds like a great tool, but I am having trouble visualizing it.
                            • dbeardslee
                              • 4385
                              • Maineville, OH
                              Steppenwolf took some pics on saturday, and here's a shot of the pvc tool in action. I took the 3/4" pvc and glued an end cap on it to make it a little more serviceable. I originally made it based on Bikerphil's recommendation. Works great, and it's cheap. You just have to make sure the 'window' stays towards the center of the head for access. Also, as Don said, a small telescopic magnet and a pick come in real handy to get the valve keepers out.
                              • Pat Kelly
                                • 3046
                                • Golden Valley, AZ
                                I used my drill press and 3/4" PVC with a notch cut in it. I have a shop towel balled-up under the valve (under the head) to hold the valve while the spring(s) is/are compressed. Pulled the keepers with a magnet.
                                Pat Kelly
                                <p-lkelly@sbcglobal.net>
                                1978 XS1100E (The Force)
                                1980 XS1100LG (The Dark Side)
                                1999 Suburban (The Ship)
                                1994 Dodge Spirit (Son #1)
                                1968 F100 (Valentine)
