I am trying to follow the wiring diagram and I am confused as to where the headlight get's it's power from. I took apart the LHS and there are four wires that are connected to the hi/lo beam switch:yellow, green, blue/green, and blue/yellow. I no longer have the RLU so I connected the blue/yellow wires and the blue/black wire. Also on the other side of the RLU plug I connected the blue/green and the yellow wires. On the schematic I was looking at http://home.comcast.net/~sidhansen/rlu/schematic.gif it shows that the blue black wire is what is the start of the circuit, and goes through depending on if it is on hi or lo. I am not using the middle console, speedometer or tach, and this is the only place I can see that would supply power, though it isn't clear. Can someone please clerify for me? I am trying to locate the main power for the headlight.
Thanks,
-Rick
Thanks,
-Rick
