Are the carb diaphrams supposed to rotate?
  • Incubus
    • 1003
    • Austin TX
    Around the base in the middle that holds the needle? Of my four diaphrams, two will move around the base and two seemed fixed. I mean you can hold the needle holder and the diaphram will slide around it. Are the fixed ones stuck from age or are the ones that move decrepit with age. If they move and they aren't supposed to, will they still serve their purpose? Other than this movement thing, all the diaphrams are intact and relatively supple.
    Thanks,
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • foreda
    • 949
    • Southwest Louisiana
    Diaphrams
    If you are talking about 78/79 carbs, I do not think the diaphrams are suppose to rotate.
    78 XS1100E Standard
    Coca Cola Red
    Hooker Headers
    1979 XS1100 Special
    1980 XS Standard
    2006 Roadstar Warrior
    • Bamper
      • 97
      • Maine
      its been a while scince ive had mine apart but if i rememer correctly dont they have a little tab on the top ring of the rubber that sits in a groove on the carb body so they cannot rotate. but i dont rememer if my rubbers (no pun intended) rotated or not i dont beleave they did. and on another note if they do rotate then that would mean there is a small gap between the rubber and the slide so it might not get the vacume it needs.
      1979 XS1100 SF (production number 572)
      1972 Kawasaki g4 TR-B with high and low transmision
      1974 kawasaki G4
      2003 Polaris 250 Trailblazer
      1975 Yamaha Enduro 175
      • Incubus
        • 1003
        • Austin TX
        They do have a tab, but I'm talking about when I have them out of the carbs. They will sit still once the carb is closed up, I just don't know if there will be an unexpected air leak that would cause the crab not to operate correctly. If they are supposed to be fixed and they instead move that could mean a seal is broken and air would be getting in instead of the diaphram working right. That's my concern.
        1969 Yamaha DT1B
        • Bamper
          • 97
          • Maine
          now that i think i back im 99% sure they aren't supposed to rotate if i get a chance later ill pull mine off and check.
          1974 kawasaki G4
          • jjwaller
            • 242
            • Gautier, MS
            No they most definitely do not rotate.
            They are clamped in place when the top is screwed down.
            Make sure they are in place all around the groove in the body and then
            screw down the top.
            John
            '81 CB900C ( 10 Speed)
            '78 CB750F ( The F)
            '76 CB400F ( The Elf)
            New '82 Honda MB5 Ring Ding
            Then: '76 CB550K
            '78 CB750F
            '84 VF1100S
            And still Looking!
            • red bandit
              • 970
              • central michigan
              The rubber diaphram is not supossed to turn on the slide. Unless it turns real easy I wouldn't worry about it. The little hole in the bottom of the slide goes towards the engine.
              79 SF parts bike.
              • Crazcnuk
                • 2980
                • Hinton, AB, Canada
                The diaphragms are fixed so as to locate the breather hole in the bottom of the slide.
                If you look, when they are together, all those holes will be lined up the same in each carb.
                '05 ST1300
                • petejw
                  • 2269
                  • sydney australia
                  There not suppose to rotate,
                  but you can pull the diaphrams off by cutting the
                  plastic top ring with a sharp knife and carefully
                  prying it off, you can then inspect the inside of the diaphram,
                  ive done this to replace them.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  1981 xs1100 RH (aus) (5N5)
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
