Middle Gear Case Help
  • dpotter58
    • Aug 2004
    • 1865
    • Southern Maryland
    Hammer and cold chisel will work every time to rotate the plug.
    yep. worked for mine
    1980 LG
    1981 LH
    • MeatTooth
      • Apr 2009
      • 175
      • Tulsa, Oklahoma
      Yes!!
      success! I got the devil plug out. I used a cut off wheel to grind a groove in the top of the plug and then the chisel and BFH took care of the rest. Thanks for all the input couldn't have done it without ya.
      Tulsa, OK
      • wa407mpp
        • Jul 2007
        • 717
        Any time you mate two different metals together, such as steel and aluminum, over time, they will bond together, the best way to separate them is to use an Impact Driver, cost about $20.00 for a decent one and no tool box is complete without one. Just remove the bit holder and put on what ever socket you need to break free the nut, bolt, or screw, and most times there won't be any damage and the fastener will be reusable.
        Fastmover
        lion". SHL
        78 XS1100e
          When you put in your new plugs, use a bit of never-seize on them, and a nylon crush washer, and go easy on the torque. If you can't find nylon or plastic crush washers, a washer off of an old sparkplug will work. Just like sparkplugs, only tighten them an 1/8 turn or so past lightly seated.
          • oseaghdha
            • 1075
            • N43.02.5,W88.14.2
            + 1 on the anti seize.
            I put it on pretty much everything that screws into aluminum.
            XS1100SF
            XS1100F
            • Rocknroll90
              • Aug 2009
              • 48
              • Kearney, ne
              A dad trick
              If u have a tight or stuck bolt and no air tools Dad said to put the wrench on apply pressure and tap the wrench or bolt with a hammer several times while trying to get it to break free. He said it was like an air ratchet with a hammering effect. Notice TAP and SEVERAL times, you r not trying to knock it loose just help with pressure.
              There is a VERY fine line between "hobby" and "mental Illness"
              I don't own a classic I RIDE one
              Brad Norton
              Kearney, Ne
              Photojournalist
              Hobbies-Family
              rock and tree climbing, rescue ropes, firefighter, Boy Scouts leader, metal detecting and camping
              age 49
              1980 XS1100SG Special- My very first bike!!!
                Hi Taylor and welcome,
                well, now the bastard is out, what next? I got mine out by filing two flats on the plug head that I could get an open-end wrench on but, like yours, the hex socket was cammed out too badly to do the plug up again, let alone undo it again the next time I did a middle gear oil change. What I did was drill the hex hole out to 6mm, saw off an M6 hex head bolt short enough that the head went down flush with the top of the plug and braze it in there. Did the final drive unit plug too. Now they get removed with a box-end wrench, no more problem.
