wiggles
  • GARTHXS
    • 1631
    • Seattle
    #46
    fall on your sword?
    Originally posted by 3Phase
    Depending on how much wrist I used I was getting 33 to 42 mpg with the new needles you gave me and the smaller jets. When it dropped down to 27 to 30 mpg again after refilling the rear tire I was more than a little concerned. WTH?
    I'll commit seppuku after I check the valves and the cam chain tomorrow.
    Regards,
    Scott
    Hopefully you wont have to , it looks like you have the situation in hand , just a matter of preflight checklist D'oh
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • thewiz
      • Oct 2006
      • 1115
      • Wilksboro, NC
      #47
      I was talin' about the manual for the TOOLs, not the bike. I know you have the bike manual, my son.
      80G Mini-bagger
      Past XS11s
      • GARTHXS
        • 1631
        • Seattle
        #48
        ahh heres the problem
        tore apart my front end today and this is what I found , all the threads on this are correct it is a pita but very doable it took me longer to get the it off than it did to dremel out the bottom race, the top one popped out with only a little bit of blunt force trauma and the bottom bearing was easy to cut off, I guess its only hard if you are trying to save the parts. the hardest part of the job was getting the front of the bike off the ground, any best practices on raising the front end , I just dont feel that comfortable with raising up the bike resting only on the center stand, especially when the back tire touches and I can see the center stand start to lift?? oh yeah this a crappy cell picture
        91 kwaka kz1000p
        Stock
        • thewiz
          • Oct 2006
          • 1115
          • Wilksboro, NC
          #49
          What the hell is that, Garth?
          Looks like a gnarley old plastic ferrule from the P-trap plumbing under the sink ... lol ... sure that's the right photo?
          80G Mini-bagger
          Past XS11s
          • GARTHXS
            • 1631
            • Seattle
            #50
            loose ends
            So I am just wrapping up loose ends repainting the TT changing the buckets for the clocks and cleaning all the parts to re install the front end , is there a specific torque for the headset ?
            91 kwaka kz1000p
            Stock
            • jjwaller
              • 242
              • Gautier, MS
              #51
              I always use a small floor jack under the oil filter or front of crankcase
              to jack up the front of the bike. Any small jack will do.
              Also a good idea to use a ratchet strap or something to tie the
              centerstand back so it cannot possibly collapse.
              John
              '81 CB900C ( 10 Speed)
              '78 CB750F ( The F)
              '76 CB400F ( The Elf)
              New '82 Honda MB5 Ring Ding
              Then: '76 CB550K
              '78 CB750F
              '84 VF1100S
              And still Looking!
              • GARTHXS
                • 1631
                • Seattle
                #52
                thanks
                I wonderd about it resting on the motor it won't damage the filter cup?
                91 kwaka kz1000p
                Stock
                • jjwaller
                  • 242
                  • Gautier, MS
                  #53
                  I've never had any problem.
                  If you're concerned, put a short piece of 1x4 between them.
                  I suppose it does depend on what the top of the jack looks like.
                  John
                  '78 CB750F ( The F)
                  Then: '76 CB550K
                  '78 CB750F
                  '84 VF1100S
                  And still Looking!
                  • GARTHXS
                    • 1631
                    • Seattle
                    #54
                    wiggles begone
                    new bearings did the trick , I rode to work today and she flies straight as an arrow, so much better I even dragged a peg and my right blinker problem is fixed too some of the wires to the switch itself came off and I sweated them back on and cleaned it all with contact cleaner what a difference. I am onsidering putting my vetter on this bike but the fairing needs a little work and paint to fit on my stocker
                    91 kwaka kz1000p
                    Stock
                    • thewiz
                      • Oct 2006
                      • 1115
                      • Wilksboro, NC
                      #55
                      Way to go, Garth ... I like 'em better when they go where ya' point 'em too.
                      80G Mini-bagger
                      Past XS11s
                      • 79XS11F
                        • 3563
                        • Ottawa, Ont. Canada
                        #56
                        If your content that the wheel and head bearings are good and tires are properly inflated then check wheel alignment. Check that the swing arm bearings are good and that the swing arm is centered to specs. If the swing arm is centered out of spec the rear end will move back and forth as the rear wheel tries to track off center but is being pulled to center by the bikes forward motion. This effect would be a mild wiggle at slow speeds but very noticeable at higher speeds.
                        Rob
                        KEEP THE RUBBER SIDE DOWN
                        1978 XS1100E Modified
                        1978 XS500E
                        1979 XS1100F Restored
                        1981 Suzuki GS1100
                        1983 Suzuki GS750S Katana
                        1983 Honda CB900 Custom
                        • 79XS11F
                          • 3563
                          #57
                          Which bearings did you change?
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • thewiz
                            • Oct 2006
                            • 1115
                            • Wilksboro, NC
                            #58
                            Rob ... he changed out the upper and lower steering head bearings, races and grease seals ... looks like he's got it right judging by his last post. He talks in a common form of California slang and is hard to understand sometimes ...
                            80G Mini-bagger
                            Past XS11s
