I have fire!
  • Incubus
    • 1003
    • Austin TX
    I have fire!
    So I finally got the second parts bike home. It's the one with the better looking ignition parts. The difference was more than I expected. I already knew the vacuum pump in the pickup coil plate was frozen and I already knew someone had repaired - or attempted to repair, I don't know which - the wires to the pickup coils. When I pulled the timing plate off, however, I made two unexpected discoveries. The first was a big piece of broken porcelain, triangular shaped, measuring about two inches at the wide end and about 1.5 inches long.. I have not found, yet, the porcelain motorcycle part that this piece broke off of, but I swear it is much to big to have accidentally slipped into the crack between the timing plate and the crankcase. I am not sure what PO was doing.
    Second, I discovered that the advancer unit was a solid piece of rust. You could barely see the joints. After I pried it off it it first looked like the rust also had damaged the end of the crankshaft. I was lucky. The crank is apparently made of better steel. It polished up fine. I replaced the timing plate and the advancer with parts from the second parts bike.
    Hit the starter button. Spark on both one and two. I didn't check three and four, but I will give them the benefit of the doubt.
    This is probably more info than anyone here cares about, but already I tried talking to my wife. If a stare was ever blanker it certainly killed the recipient. She supports my motorcycle ventures as long as I don't drag her into them.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    Patrick, that is all a guy could ask!!! :-)
    Patrick
      Patrick, maybe the piece of porcelain fell into the cover when something was dropped or broken next to the bike as it was being worked on, then the cover was put back on the engine. Does it look like a broken dinner plate or what?
      It's nice that your wife supports your hobby but -- beware the stare of the Basilisk!
      Regards,
      Scott
