spooge hole
    • 2117
    spooge hole
    I bled my brakes the other day and cleaned out the spooge hole.One question-i removed all the fluid from the master cylinder and twisted the reservoir to reveal the spooge hole.Does the reservoir actually come apart if you pry it?Just curious.If it does what actually holds it on and will it go back on without leaking?I actually want to removed the black paint from the master cylinder.
  • GARTHXS
    • 1631
    • Seattle
    yes
    if you pry very carfully there is an o-ring that seals the cup on , with the cup off it is a much easier to get to the holes, I used a guitar string an that worked well just clean with new brake fluid nothin else or you will contaminate you fluid
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
      Keep on twisting, and prying up carefully with a putty knife or other thin device, and the reservoir will pop right off of the body. The reservoir seals to the body with a large o-ring. Gravity also helps keep it on...
        • 2117
        Ok Thanks Ken! Brakes are good now-Spooge hole is easy to find if you grab a hold of reservoir and twist- hole is then visible!
