Where can I find fuel Ts?
  • skyhead
    • 16
    • Montrose, IA
    Mine are worn and the only I can find on ebay are 37 dollars for 2!
    They go on a 79 special
    1979 XS1100 special
    There have been a few threads on this topic lately. Try searching for TEE, instead of just T.
    • skyhead
      • 16
      • Montrose, IA
      ill give that a shot... i did only search T..
      i normally try to do a search before making a new thread
      1979 XS1100 special
      • skyhead
        • 16
        • Montrose, IA
        after some reading... think ill just take the rubber coating off and put some o-rings on them...
        thanks for the search suggestion!!!
        1979 XS1100 special
        • Xcess11
          • Jul 2008
          • 20
          • Las Cruces, NM
          One possible source
          You can get Yamaha fuel tees (pipe, joint per yamaha wording) from boats.net online for $4.28 ea if that would fit your needs. I've ordered from them many times and been very satisfied.
          LINK http://www.boats.net/parts/detail/Y-...376-00-00.html
          What Is:
          2003 Kawasaki KDX 200
          What Was:
          2001 Yamaha FZ1 - WarpDrive!
          1987 Kawasaki ZL 1000 - Eliminator
          1983 Honda CR 250 Glamis Blaster
          1988 Kawasaki KDX 200 - Stolen!
          1974 Suzuki GT 750 - Water Buffalo
          1984 H.D. XLX 61 - Good Riddance
          1976 Kawasaki S3 400 - Two Smoke
          1979 Honda CB 750F - Black Beauty
          1974 Kawasaki H1 500 - Mean Green
          1971 Suzuki TC 90 - 15 Y.O.'s dream!
          • thewiz
            • Oct 2006
            • 1115
            • Wilksboro, NC
            Also there are these ...
            http://www.mikesxs.net/products-34.html#products
            80G Mini-bagger
            Past XS11s
            • dbeardslee
              • 4385
              • Maineville, OH
              Sky - Be thee aware, all tees aren't created equal. There are different sizes depending on the year of the carbs. On the '79 I think they're both the long ones, but I wouldn't swear to it. If you decide to order new ones, make sure you're getting the right size.
                • 1376
                Size DID matter!
                On my 79 special the Tees were not the same size. The fuel inlet Tees were "wider/longer" than the tees which were used for the float/fuel bowl vents. Also when I dry fit the "vent" tees inside the fuel inlet orifices they were looser/not as tight as they were in the vent orifices. Possible, IMHO for them to not seal and then permit leaks.
                See this: http://www.xs11.com/forum/showthread.php?t=20455
                For a good thread with pics of the O-ring process, see this:
                If you do decide to get the Tees from Mike's or Motorcylecarbs.com then be sure to get the longer/wider ones. I ordered and received the shorter ones and to this day have not installed them as replacements for the fuel inlet tees. Great for the vent tees, but I'm not going to put them in as replacements for the fuel inlet tees.
