Dyna Coil Question
  • sambodie
    • Mar 2003
    • 26
    • Channelview, TX
    Dyna Coil Question
    Has anyone with a 81 Special tried the 3.0 ohm Dyna Coils?
    I have searched the board and I find two answers about the rating of the coils.
    1) on the FAQ says 3.0 ohms for the 81 model
    2) says 2.5 Ohms.
    The stock coils Ohm out at about 2.75 Ohms on my meter Dyna List a 2.2 Ohm coil and a 3.0 Ohm coil. Would either of those work?
    TIA
    SAMBODIE
    Sam Bodie
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    I've got Dyna's address and phone # around here someplace. They have tech specialists. I'll find it and post it.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • sambodie
      • Mar 2003
      • 26
      • Channelview, TX
      Confused as a run-over dog.
      I just got off the line with Dyna's tech people. They said to use a 1.5 ohm coil with a resistor. I told them it was an 81 Special and I am given to understand that it's a 2.5 ohm setup. Still the same answer from them 1.5 ????
      The problem is I have already purchased the 3.0 ohm coils and I need to know if they will work or burn out the other ignigion componets.
      Does anybody have a clue?
      TIA.
      Sam Bodie
      • ratbyk
        • 994
        • Sooke BC
        Dyna Coils
        I would suggest you use your 3.0 ohm coils and install a 1.5 ohm resister which would cut you back to the experts recommendations of 1.5.
        Ken?Sooke
        78E Ratbyk
        • sambodie
          • Mar 2003
          • 26
          • Channelview, TX
          Would that not them make the total resistance 4.5 ohms?
          Sam Bodie
