Hello, it's me again. Two days ago my 1981 XS1100 Midnight Special stopped starting for me. I've had to push start it ever since then. I went to a mechanic and he told me to replace the regulator rectifier so I did and that didn't work. All my fuses are good and I've checked the wiring and that all seems in order. It'll try to start but it doesn't get anywhere. It's like 1 turn over then something like humming as it tries again. Any help would be greatly appreciated. Thanks.
Stopped Starting
Sounds like a starter clutch. I'm not certain, but if the starter is spinning, but only humming, and the engine is not revving, the starter is disengaging when it's not supposed to be.1980 XS850SG - Sold
-H. FordComment
You CAN post video. Post it elsewhere, and link to it in your post here. People do it all the time.
If the starter is making noise, is it spinning, or is it just loaded against the engine? You could take it out (3 bolts) and ground it to the frame, then see if it's spinning.
Does it make any difference if you use the starter button or try shorting cross the starter solenoid?1980 XS850SG - Sold
-H. FordComment
Sounds like either the ground connections are bad, or the starter's given up and needs to be replaced to me.
Starter drives tend to not engage or will disengage during starting and whine..
Solenoids can sometimes be the problem, but yours sound like it's working to me...'82 XJ1100J Maxim (has been sold.)
'79 F "Time Machine"... oh yeah, Baby....
(Sold back to Maximan)
2011 Kaw Concours 14 ABS
"What we have here is a failure to communicate."Comment
Your battery voltage & charging voltages sound right.'82 XJ1100J Maxim (has been sold.)
I think it's loaded against the engine, the starters not spinning free if that's what you mean. Like is said it'll turn over once or so and then it can't anymore, it'll still try though. Tried jumping the solenoid and still get nothing, just the same "its trying but cant quite get it going".Last edited by Sleeping; 08-06-2009, 03:05 PM.1981 XS1100L Midnight SpecialComment
Not an electrical guru for sure, but that sounds like either your battery is bad (yes I know you just replaced it and yes it CAN still be bad, not likely but could be) or your starter is giving up the ghost.Life is what happens while your planning everything else!
78 XS750Comment
Just for S&Gs try jumping it off your car battery. If it starts, it is very likely the battery. Otherwise, it could be a bad spot in the starter motor.
I had a Toyota Truck that did this. Hit the starter key several times and eventually it would start....for a while....then it would not. Sometimes you just turn the key and it starts, other times hit the key some, other time ALOT. Finally replaced the starter, never had a problem again.Life is what happens while your planning everything else!
78 XS750Comment
I had that same problem on one of my previous cages too. Finally got to the point where I held a large wrench on the floor in front of the passenger seat so I could get out and touch the solenoid to turn the starter and get it to start. Replacing the starter finally fixed the issue.Just for S&Gs try jumping it off your car battery. If it starts, it is very likely the battery. Otherwise, it could be a bad spot in the starter motor.
I had a Toyota Truck that did this. Hit the starter key several times and eventually it would start....for a while....then it would not. Sometimes you just turn the key and it starts, other times hit the key some, other time ALOT. Finally replaced the starter, never had a problem again.1980 XS850SG - Sold
-H. FordComment
Hey Bug,
That works if the solenoid is whats bad, mine was bad spot on the starter motor windings. If it came to rest with that spot on the brushes it would not start, if you keep hitting it with voltage it would eventually rotate enough to get past that spot and work fine until the next time that spot landed on the brushes. Had the same thing with an in tank fuel pump on a Dodge Dakota, that sucked to change out.Life is what happens while your planning everything else!
78 XS750Comment
Pull the starter off and check the brushes. Spec for the min length is in the book. While your in there clean and re- grease the gears and bushings. Bench test and it all is well reinstall and try it. At least that way you know its not a starter problem if it still dose not work and you have a rebuilt starter.wingnut
81 SH (Daily Ride)
81 XS 400
Thomas JeffersonComment
