loss of everything
  • sparky30
    • 19
    • lancaster pa
    loss of everything
    Hello everyone..Last nite took my bike out for a ride.Got bout 4miles from the house turned the corner and i lost all power to my bike..pulled over to the side of the road. i started to make sure my battery term were not loose of course it wasnt that.Then i checked my fuses all of those were good. checked all my grounds they were all intact and corrosion free. got home checked my batt with my voltage tester i had 13volts at the battery..what would cause me to have no juice at all...thanks in advance,chad
    1978 xs1100 e
  • randy
    • Dec 2003
    • 4521
    Main swith connector inside headlight shell may be melted/ corroded - take your pick
    Or the main switch may just be broke.......\
    There are three wire there, red, blue, brown. You can troubleshoot the switch by jumping the red to the brown and blue and everything should come alive.
      • 2104
      If you have the glass bottle type fuses you might want to check continuity 'cause sometimes they look good but are'nt. Also the main fuse on the left side could be suspect. Let us know what you find. HTH
      • sparky30
        • 19
        • lancaster pa
        I have the spade type fuse block which i bought from tc.I changed all the fuses with no luck at all.I will checked the head light bucket to see whats goin on there
        1978 xs1100 e
          Changing that fuse block doesn't change your MAIN fuse. Go back to Schming's post.
          BUT.. if it is the main fuse, there has to be a reason it blew?
          • randy
            • Dec 2003
            • 4521
            We can't be sure he even HAS a main fuse ( I assume you meant the hidden one on the 80 an up). He hasn't told us which model he has.
            • sparky30
              • 19
              • lancaster pa
              its a 78 xs1100
              1978 xs1100 e
              • randy
                • Dec 2003
                • 4521
                The main fuse on the 78 is on the multi-fuse block under the right side cover.
                  • 2104
                  Hey sparky30, the only other thing it could be is You might have accidentally rode your '78 XS1100E 4 miles from your home right smack dab into a "DEAD ZONE" Seen it on TV happens all the time. There is another one on 403 South as soon as you get into Johnstown Be vewwy cawwfull. Lose reception there all the time probably like I will with this post and i even have verizon. No really did You find out whats up with it yet?
                  • sparky30
                    • 19
                    • lancaster pa
                    thanks for the input everybody what it ended up bein a connecter come loose
                    1978 xs1100 e
                      Which connector? Helps to know where to look, specifically for the next guy.
                      • sparky30
                        • 19
                        • lancaster pa
                        it was the starter solinoid connector
                        1978 xs1100 e
