I'm getting ready to order from motionpro, but I'm leary of getting a cable that's too short or too long. Anyone with drag bars know their measurment? I'm guessing it's in the 29" range for the throttle. Can I take the same 14" off from the clutch cable?
Drag bar cable length...
Josh Yoquelet -- I'm having dreams of my XS
'79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
'79 XS11SF "bobber"- Rotted in a pine tree for 10 years
'81 Air forks w/23,000 miles
New steering head races and bearings
'78/'79 standard wire harness
Drag bars, w/Mikes controls
T.C.'s fuse block
PNM Coils
7mm Dyna Wires
NGK Resistor Caps
Custom 1" clutch and 9/16" MC
http://xs11bobber.tripod.comTags: None -
I used the stock cable for mine. it could probably be a few inches shorter but it is not WAYYYYY to long, hardly noticable really."Beware of any man that owns a pig farm"
79 XS1100 modified standard
straight pipe 4-2 exhaust
Owned 83 Honda V65 Magna
Owned 02 Vstar 650 classic
owned 85 Honda Shadow VT 700C -
some pics
owned 85 Honda Shadow VT 700CComment
Mine does have a 1 to 1 1/2 in riser on them. Dont know if you do or not, but would suggest it with a drag bar"Beware of any man that owns a pig farm"
Hi Josh,
a few inches too long can be coped with. As little as an inch too short is a bitch.
Set up the bars as you want them. Check if you can turn them lock to lock when mounted direct or if you need risers.
Use the regular cables in place at the carbs and clutch and taped to the levers where you think they aught to be and try them lock to lock to see by how much the new cables need to be shorter.Fred Hill, S'toon
"The Flying Pumpkin"Comment
I went out and remeasured. Maybe I'd have a better end result if I only went 6 3/4" shorter than stock on the throttle. Everyone think I'll be ok taking 6 3/4" from the clutch side as well? Is that a good theory?Josh Yoquelet -- I'm having dreams of my XS
T.C.'s fuse block
PNM Coils
7mm Dyna Wires
NGK Resistor Caps
http://xs11bobber.tripod.comComment
Hi Josh,
yeah, but it's only a theory. That bike is older than you are, God knows what length of cables it's various POs may have put on it. The only safe way is to tape the existing cables in place on the lever and twistgrip where they look right on your new bars and don't think "I should take X & Y inches off them" but measure the cables from their far ends to the levers and think "The new clutch cable should be XX inches long and the new throttle cable should be YY inches long".Fred Hill, S'toon
How'd you get that to work out? Can you take some closer pics? Because I thought about a riser since I'm so close to the air valves on the forks. There's probably 3/16" between the bars and air caps.
Fred, I think taping will work easily with the clutch side. I'm going to have that upward bend at the twist grip for the throttle. I think I can just use a little imagination and flex it where I think it needs to be. I think I'll be safe with the 6 3/4" if too long is ok, because I have about an extra 12" right now.Josh Yoquelet -- I'm having dreams of my XS
T.C.'s fuse block
PNM Coils
7mm Dyna Wires
NGK Resistor Caps
