I have an 81 xs1100, pod filters, straight pipes. Runs good up until 6,000rpm then flattens out ( no more power) I know with this set up it needs the carbs re jetted, I am going with three sizes bigger from the carb jetting recommendations page I found on this site. http://www.xs11.com/forum/showthread...=&threadid=382 Any way do I rejett the main jets as well as the pilot jets? or just the main? I am starting with 120's for the main and going up three sizes from that. Followed by the stock pilot jetts being 42.5 and going up three sizes from that. Does this sound right? Please somebody help! Thanks Erik
need help carb questions
I have not played with rejetting the carbs yet, my bike is still stock pipes and intake system. I have heard many people try to run straight pipes and had nothing but trouble out of it trying to get the jetting setup right. Most go back to some type of muffler.Life is what happens while your planning everything else!
78 XS750 -
I think your set-up could use a bump in the mains. 117.5 mains and 45 pilots should run good for you.'81 XS1100 SH
Sep. 12th 2015
RIPComment
I am running 120 mains, 42.5 pilots, and the upgraded needle/tubes from MikesXS, on my 80G. I just have a K&N air filter element, and MikesXS coils (not the green ones).
My plugs are very light, but within normal coloration. Floats are down 2mm.
127.5 would seem very large for your mods.
Since the stock size for an 81 is 115 or 110 (std or spcl) you are going up either 5 or 7 sizes from stock. You would go up either 1 or 2 pilot jet sizes.Last edited by Crazcnuk; 08-04-2009, 02:27 AM.Nice day, if it doesn't rain...
'05 ST1300
'83 502/502 Monte Carlo for sale/tradeComment
