Getting ready to change the tree bearings. Ordered a set from All balls. I have a lower XJ triple tree with a bearing on it I was going to practice on. Looks like I'll have to cut them off with a dremel Eh?
While it's off I'm going to change the fork seals. The upper forks have a little rust that has attacked them in a few low spots but I think they can be cleaned up.
Aquirred a set of front forks off of an XJ11 that have the adjustment knob at the top and air assist. Anyone know if the additional valve dampening adjustment could be used with th 79 upper forks along with the XJ dampening rod?
, bad enough that I wont be able to use them.
