is it bad?
  • greg maz
    • Feb 2008
    • 219
    • Arlington Heights, CA
    is it bad?
    go ahead, hit me with your best shot:
    did the 2nd gear fix, resealed pan, clutch basket back in... there is a big "extra" washer laying around now... the one on the very left of the counter shaft, between the wall and middle F!ing gear...
    just poor or very bad?
    82 XJ1100 Klonk= SOLD
    No longer active member.
    welllll.......The gears in there will tend to slap around like a bad rod bearing without it, as in.....yep....you had better go back in one more time. Sorry
    • greg maz
      • Feb 2008
      • 219
      no you didn't
        Yeah... You're gonna have to get back in there and put it back. It's rather important that everything is spaced correctly in there. Good thing you caught it now, and not while out on the road.
        • greg maz
          • Feb 2008
          • 219
          used "right stuff" for gasket,
          let's see how it affected the threads
            I used the Permatex Ultra Black on all my covers and oil pan. it gets a little on the bolt threads, but as long as it's dried, it comes off pretty easy. Just be sure you use a wire brush to clean it all off before putting it back together. Brake parts cleaner is a good solvent for the mating surfaces, to be sure it's nice and clean for the gasket stuff to stick to. Might want to loctite (blue only!) all the bolts too.
              Hey Greg,
              Are you sure it's that washer?? There are two large thick thrust washers for the clutch, one down inside the clutch between the boss and the basket, and the other slightly smaller diameter one that goes behind the basket on the clutch shaft next to the engine. Just wanted to make sure that you verified that you had those washer in the right place as well. Tod showed us what happens if you mix those washers up, the bearing on the clutch shaft doesn't get lubed properly, and can cause damage to the clutch basket bearing!
              • greg maz
                • Feb 2008
                • 219
                I think it's collar 32, the ring behind the countershaft bolt, it has the same diameter, but it is odd to place back in...
                • greg maz
                  • Feb 2008
                  • 219
                  it feels like the bolt loses vertical contact with the shaft because of that spacer, but checking on the other side (inside the engine) I think I see a washer between middle gear and the wall. The middle gear and the gear next to it have a couple mil. play.
                  So it is either that collar which is hard to align because of the very small lip it rests on, or another washer from the gear assembly.
                    Hey Greg,
                    STOP!! IF it's #32, then it's not ON the countershaft on the INSIDE of the tranny case!! #32 fits on the outside of the case, on the clutch side, it's the large collar washer that goes with the large bolt/washer that holds the countershaft in place with that 51 ft/lbs of torque. The larger washer with the bolt has a SHOULDER and that collar needs to be well centered in it, otherwise it will not torque correctly, and could even vibrate loose...just ask 3Phase/Scott!
                    • greg maz
                      • Feb 2008
                      • 219
                      thanks a bunch TC, as always
                      I figured it out but forgot to mention the countershaft is still in (being all lazy) and that I was looking at the bolt from the outside of the engine
                      was waiting for confirmation to proceed reassembly
                      cheers
                      "I did it myyyyyyyyyyyy waaay"
