that's it going ape shhhh...
  • greg maz
    • Feb 2008
    • 219
    • Arlington Heights, CA
    How the F! do u get that shaft with all the gears (but 5th) out?
    son of a c!smith!
    got 5th out, got counter shaft with notch out
    read somewhere that the gear box could grenade sometimes and throw you off,
    well it looks like it will but it won't be an accident
    some serious anger management session with my favorite tool the hammer about to go down
    82 XJ1100 Klonk= SOLD
    No longer active member.
    Was the bike put into 4th gear first?? That is mandatory to get everything out. Remove the clutch, then the oil pump idle gear, and the shift fork shaft (remove the circlips from both ends, and tap it out the right side of the engine). Other than that, the countershaft is the only thing you have to take out. That is what 5th gear WAS on, and it probably slid out through the hole on the left side, right? Once you remove 5th gear on the left side, and the bolt on the right side of the countershaft, the countershaft will just slide to the left about an inch, and almost fall out. You might need to tap it from the right side with a wooden stick and a small mallet, after removing the bolt, to get it to slide to the left, and out of the hole.
    • greg maz
      • Feb 2008
      • 219
      here we go thx
      I swore I wouldn't swear anymore until both rubbers were back down...
      F! it
      will try the manip now
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        In all actuality, I found lots of alcohol was very helpful. After blacking out face down in the gear box, it was all clear to me. Well, kinda....
        How not to fix second gear
        Ich habe dich nicht gefragt.
        • greg maz
          • Feb 2008
          • 219
          I bet I kicked it out of gear
          As anyone noticed one of the pan's screw doesn't clear where the kick stand is welded to the frame - talking XJ here - or is my block not aligned? I had to dremel thru.
          Busted a $9.99 impact driver from autozone (the only one that carried it in my hood) on the shaft, a $15 torque wrench did it better.
          • greg maz
            • Feb 2008
            • 219
            Read that thread: will try tomorrow
            if I find money for beer
            • GARTHXS
              • 1631
              • Seattle
              funny stuff
              I remember that one it made me lmao
              91 kwaka kz1000p
              Stock
              ( Insert clever quote here )
              • Bigfoot
                XS-XJ GURU
                • Sep 2005
                • 1422
                • Kansas City, Missouri
                I seem to recall that same pan bolt on the my XJ was a pain. Took a little work to get it out because of the kickstand but it was doable. I think it was easier to get the countershaft out when on the center stand because gravity was helping. Are the shift forks out of your way. Once they are, you should be able to start wiggling the countershaft as you slide it out and it will come.
                Harry
                '79 Standard
                '82 XJ1100
                '84 FJ1100
                Acta Non Verba
                • XJOK2PLAY
                  • 2099
                  • Skiatook, Ok.
                  Harry- I know exactly which pan bolt you speak of on an XJ... they are a pain in a particular place....
                  Still wondering who was the wiseguy at Yamaha that thought it was a good idea to use allen head bolts...
                  (I know... aluminum blocks... etc...) still don't like 'em...
                  Ivan- Too funny.... and more than likely too true... which makes it funnier!
                  2011 Kaw Concours 14 ABS
                  • greg maz
                    • Feb 2008
                    • 219
                    Apologies
                    I opened the beast at 300303 miles, drove to pasadena and back in full traffic
                    thx Yamaha to make it monkey proof
                    • greg maz
                      • Feb 2008
                      • 219
                      I meant the 2nd gear fix was done
                      and today I rode 40mi test in town
                      apart from clutch slippage which could be do due too much oil and bad clutch adjustments,
                      tomorrow Angeles Crest
