The Quest
  • geniusloerts
    • Jul 2007
    • 420
    • fayetteville, Arkansas
    The Quest
    OK, where can I find afordable fork seals? This is for my '79 Special. There seems to be 2 seals per side, inside of the upper tube. I have the larger one, I am looking for the thinner one. I saw them on bikebandit.com but they are a whole $40..... Is there a better place and better price?
    Thanks
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
  • foreda
    • 949
    • Southwest Louisiana
    Try Ebay
    Might find some on ebay..
    78 XS1100E Standard
    Coca Cola Red
    Hooker Headers
    1979 XS1100 Special
    1980 XS Standard
    2006 Roadstar Warrior
    • geniusloerts
      • Jul 2007
      • 420
      I guess the ones in particular i need are the 37mmx49mmx4mm seals
      -Pod Filters
      -4-1 pipe
        They say to get actual OEM seals.. that the aftermarket ones suck.. but I don't have personal knowledge of this. Post the part number and I'll check a few places I haunt.
        • Montreux_Blue
          XS-XJ Guru (Deceased)
          • 1143
          Famous Myspace quote:
            Ya know.. you say you don't do drugs. There's probably a REALLLLY good reason for that.. lol.
            • Montreux_Blue
              • 1143
              I had to quit, they were making me paranoid.
              • tw1980
                • Apr 2009
                • 662
                • Bend OR
                +1 to that I tried the aftermarket thing twice and then ordered them from my yamaha dealer.After lots of leaks.
                Terry
                1980 special (Phyllis)
                • geniusloerts
                  • Jul 2007
                  • 420
                  Looking for the thinner seals
                  I already have the thicker seals that are 10mm thick i am in need of the ones that are 4mm that are labeled as the 'oil washer seals' on the part list. This wouldn't be a problem had my dad not tried to see how much psi my forks would hold..... :/
                  I can't get the 4mm seals from a yamaha 'stealership'
                  any great ideas?
                  -Pod Filters
                  -4-1 pipe
                    On Yamaha's parts site, I don't see anything under a 79 special on the forks that is called that. Do you have an OEM part number?
                    • geniusloerts
                      • Jul 2007
                      • 420
                      here it is
                      4 3H3-23146-00-00 SEAL, SPACER * 2
                      -Pod Filters
                      -4-1 pipe
                        Wow... looks like another one of those "Unobtainium" parts from my search. Maybe somebody else knows of an aftermarket supplier. Sorry..
