NOS Piston ring alert
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    Hey guys and gals,
    There's a NOS set of piston rings for the first oversize for sale $35 !!!
    Described as: "FOUR New Nos Yamaha XS1100 Piston Rings Ring Set s .25"
    Here's the link:
    Good deal if you're doing your first re-build.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
  • b.walker5
    • Feb 2009
    • 1745
    • Invercargill, New Zealand
    So who got them, I just hit the buy now only to be told the item had ended
    • Lamric
      XStremely XSive(Deceased)
      • 410
      • Kenley, Surrey, England
      Sorry guys, that was me
      Brian
      • 79XS11F
        • Jul 2006
        • 3563
        • Ottawa, Ont. Canada
        Their not much of a "score" unless you have a set of 1st over size pistons to use them with. This is because to make them fit the standard pistons or the ones you currently have in your bike, you will be filing them to correct the end gap. If you have to file them to use them the amount of over size is not as important. Sorry
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • b.walker5
          • Feb 2009
          • 1745
          okaaaay........??????? So why would one buy oversize rings to fit standard pistons ??? or am I missing something here.... I have 1st over pistons already, and I'm assuming Lamric has some too, unless the Poms (sorry Brian) do something different to us here in NZ.
          • 79XS11F
            • Jul 2006
            • 3563
            If you have 1st. over size pistons then 1st. over rings are the best bet but 2nd. over size rings could also be used with the end gaps adjusted accordingly. In ether case the rings only create the seal between the wall and the piston. The piston to wall clearance is the real important spec to keep an eye on when rebuilding. Putting new rings into old bores that do not get a hone will in most cases lead to excessive oil burning. With no hone done new rings of any size will not seat properly. If you hone you may lose your piston to wall spec. So keep an eye on that when you make use of these rings.
            If your already on 1st. oversize pistons, a "score" would be a set of 4 2nd. oversize pistons and rings.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
            • b.walker5
              • Feb 2009
              • 1745
              Sorry, but I think we have our "wires crossed" here. let me explain betterer . I'm not on 1st over pistons, I have 1st over pistons and i'm going to fit them once my local machine shop bores and hones the barrels to the correct size (and i get some rings to match). I've spent many years building engines, albiet mostly GM V8's, and would never consider fitting oversize rings on standard pistons, or 2nd on 1st, or any combination for that matter. Other than desperation I cant imagine why anybody would
              • 79XS11F
                • Jul 2006
                • 3563
                Will that maks a lot more sense. I didn't know you were gathering parts for a build and already had the pistons. SO yes, a good score.
                Rob
                1978 XS500E
                1981 Suzuki GS1100
