Wanted to update everyone on the results of the work done by TC and me back on July 4th. When I took it to TC I was getting in the low 20's in MPG but now I am getting 39 MPG. Huge improvement. The second gear fix and other gear fixes worked out great the shifting is smoother and it no longer grinds 2nd and misses 2nd. It is alot easier to shift from 1st to 2nd. After replacing the front tire it cornes better and holds the uneven pavement better. I have put about 400 miles on it and am very satisfied.
I am very greatful to TC for fixing Echos and it just show what can happen when you let a GURU work on our rides.
Thanks again
Thanks again
And that mileage, awesome!! For the folks, his bike is an XJ, with stock airbox with custom made foam airfilter element, and his exhausts are modest straight pipes welded onto his headers by his brother..I think they might have a simple louvered baffle in them, but can't remember exactly, and his carbs are jetted OEM with 112.5 mains, and pilots. WE just cleaned them right "ONCE", and then vacuum synched using the YICS tool, the pilot screws are IIRC 1.5 ~ 2 turns out...I think I set them 2 turns due to the air filter and pipes.
Remember AL, the #2 plug hole was slightly buggered up by the PO, so note the plug angle, and restart it with your fingers to ensure not to cross thread it. OR...you could just pull the other 3....1, 3, 4 and leave #2 alone for now. They are NGK BP6ES as well, with stock coils.
I meant to type STOCK pilots..just got in a hurry! He wrote/PM'd and said he'll be checking the plugs and will let us know. Forgot to mention the floats were set to 23mm since I didn't have that fancy clear tube, and didn't have the time to do it that way anyways...we were in a time crunch situation. I was just glad to hear that it's running well. He gets better mileage than I do, but then again, I'm a bit heavier wristed!
