81 XS1100H replacement windscreen (Vetter?)
  • pinkelephant
    • 71
    • Effingham, IL
    I have an 81 XS1100H with the original fairing and saddlebags. the windscreen needs replacing but nobody sells one for this model. When sitting on the bike it looks just like a Vetter Windjammer fairing. the (windscreen) mounting hardware looks the same. is it a vetter windscreen?
  • CatatonicBug
    • 6117
    • Clinton, UT
    It may be a vetter. Vetter sells those windshields directly from his website, or they are available on ebay from several sources. If you post a picture of the fairing, it will be really easy to determine whether it's a vetter or not. Does it look anything like mine? Yours probably has the square headlight though, right?
    • pinkelephant
      • 71
      • Effingham, IL
      I had it parked beside a vetter last summer and they looked the same from the back. same pocket covers and windscreen mounting. That bike is 300 miles away now and I have no way to compare. I know it's a windjammer knockoff but there is a no-return policy on craig vetter's site and he won't answer my e-mails. I don't want to make a $150 mistake.
        • 7830
        If it has the Yamaha tag near the wire connection on the left side, it's a Vetter. ALL the OEM Yamaha fairings from 1980 up are Vetter designs. The 1978 was a Pacifico, and used a different windshield. The 1979 was a "mix", and you need to look at the windshield. The Vetters have an arc on the front lower part of the shield, early Pacifico has a flat section on the lower front.
        • pinkelephant
          • 71
          • Effingham, IL
          it does have "yamaha" on the top of the plug plate
            • 7830
            Then you can safely buy a Vetter replacement for it.
            • pinkelephant
              • 71
              • Effingham, IL
              I knew of this site but never came and asked. I have been trying to answer this for a month now online by asking windscreen sellers if it will fit my bike. not one of them even replied to my msg.
              I plan to ask all my questions here first from now on. thx
              • CatatonicBug
                • 6117
                • Clinton, UT
                Good idea. No shortage of quick answers around here! Glad you got it figured out.
                • Cobia
                  • Jul 2007
                  • 1587
                  • Palm Beach County, Fl
                  Windshield for you
                  Hey Pinkelephant,
                  Check your messages.
                  1980G Standard, Restored
                  Kerker 4 - 1
                  850 Rear End Mod
                  Automatic CCT
                  1980GH Special, Restored
                  '82 XJ1100 (Sold)
                  • webbcraft2150
                    • Sep 2002
                    • 1605
                    • AUSTIN.TX
                    If you have the OEM Vetter/Yamaha fairing, you can buy any Windjammer series shield and it will fit. I cut my own from a +/- $30 piece of 3/8 acrylic plastic. Not a hard job at all and it allows me to use "tinted" plastic and cut the height where I like it.
