Is the ballast resistor holding me back?
  • egleaves
    • May 2007
    • 441
    • Sacramento
    I just installed the 3.3 ohm coils from Mikes XS and its running a bit rough and sporadic. Should I have bypassed the ballast resistor? In searching the forums I found some posts suggesting that the resistor should be taken out of the equation, but nothing solid one way or the other.
    I know this, because Tyler knows this.
    1980 SG
    3J6 003509
    Kerker 4-1 (sans baffles)
    Fuse Block Upgrade
    Mike's XS Green Coils
    Pods w/Homemade Velocity Stacks
  • John
    • 5117
    By pass the resistor. The 3.3 ohm coils are made to function with iut a resistor.
      • 7844
      Yes, bypass the resistor. It's actually very easy. Unplug the two wires from the resistor, remove some of the wrap and plug them into each other. You then need to tape them up so they will NOT short against the tank!(don't Ask!!)
      • egleaves
        • May 2007
        • 441
        • Sacramento
        Yep, that was the ticket. Thanks guys, for confirming my suspicion!
        1980 SG
        3J6 003509
        Fuse Block Upgrade
