spitfire worn early?
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    my rear is about toast...
    the front still looks good though.
    i do alot of commuting with a little mountain riding on the weekends.
    unfortuantly i can't find my paperwork for the spitfires so i can't say for sure how many miles are on them???
    i put them on right after the suchess rally maybe 5-8k miles ago?
    i never peel out. i have chirped just a tad a couple of times while engine braking though.
    i read these tires should last a long time. unfortuanitly i did alot of freeway riding when i first got them before i found a short cut through the twisties to work. plus the p-cola trip pretty much did them in.
    i weigh about 200 with gear and never ride anyone. i check the pressure alot to make sure it's good. how many miles have you guys been getting on the spitfire rears?
    thanks
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    gold valve emulators
    vmax tensioner
    Rifle fairing
  • lvrsnr
    • 114
    • Kelso, Washington
    I've only got 4,600 miles on mine, but just went out to check them out and I think they've got another 4,500 in them easily. I do like pushing it off the line and thru the corners, but only weigh 170 and almost never ride two up. one thing else is that I normally run the air pressure on the lower side of the specs. 26 at the rear and 30 up front, that seems to keep them round (cross section) longer.
    Alias Larry R in Kelso WA
    When in dought, punch it.
    XS1100LG Precious current
    XS1100SF Ruby gone to a better home
    KZ900B MIA stolen (ALL bike thieves MUST GET OFF THE PLANET more politically correct ???)
    • dbeardslee
      • 4385
      • Maineville, OH
      I just went out and measured the tread on my rear and it shows .161" of tread at the center of the tire. New they had 9/32nds (.28125"), and I currently have 2,313 miles on them. I'm 195 lbs., the bike is nekid, and I ride fairly aggressively with considerable throttle twisting along with the accompanying hard braking. At the current rate of wear (assuming it remains constant) I should be due for a new rear at 5300 miles.
      • yamahansolo
        • Aug 2007
        • 1113
        • jawga
        found the receipt.... october 24th 08...
        after the fla trip i have about 22,000 on the clock... if i remember right i has around 15k on it in sept 08.... i forgot to write it on the paperwork so i am not sure??? that put me around 7 grand on the tires... the front still looks great though...???
        79 xs11 standard
        8mm msd wires
        tkat fork brace...
        Fox shocks...
        led's gallore...
        renthal bars
        vmax tensioner
        Rifle fairing
          • 7712
          Front tires will usually go about twice the rear. I get about 15K on my Dunlop Elete II rear tires. I know have an E3 on the rear of the MNS, so I'll have to see how long it will go. I only have about 3K miles on it, so it may take a while, as I use the Standard more often than the special.
          • Bob Falter
            • 321
            • Ely, Iowa
            Assuming the performance is about the same, you need to figure the cost/mile when comparing tires. I have used a lot of Dunlop Elite II’s. I get about 10,000 miles on a rear (not as good as Ray). I used to get them for around $115 delivered. I pay $15 to get a tire mounting so I include that to come up with a total cost of $130. That divided by 10,000 miles comes up to 1.3 cents ($0.013) per mile. I just ordered a rear Bridgestone Spitfire to try out. It cost me $71 delivered and will cost me $15 to mount ($86 total). So, to do as well as the Dunlop cost wise, it has to get 6,615 miles. I’m hoping for better,,, and for good performance.
            Bob
            #1 ’79 XS11 Special
            #2 ’79 XS11 Special
            '97 V-Max
            '01 Dyna T-Sport
            • BossMaverick
              • Aug 2008
              • 130
              • Montana
              I was thinking about posting the same thread on my rear Spitfire. I have about 3,000 miles on it and guessing it will last to 6,000 or so. Prior to the Spitfires I have a old worn dried out set of Metzelers that came on the bike (the front was even mounted backwards). So far I love the Spitfires for grip but I'm a little dissapointed on tire life. I know I won't get as much life as an average person due to a higher speed limit and ultra-chip sealed highways in this state, but I was at least hoping for 8,000 miles.
              With that being said, I would buy another set of Spitfires because I would rather have traction then super long life.
              1980 XS1100 Standard "Touring"
              Fairing, Trunk, and Bags
              850 FD
              Fork Brace
              Progressive Front Springs
              Engine Guards w/Foot Pegs
              Oil Cooler
              Throttle Lock
              Uni Air Filter in Airbox
              2009 Suzuki Bandit 1250S ABS
              • yamahansolo
                • Aug 2007
                • 1113
                • jawga
                yes they do hold well!!! my fiend witrh the ninja 250 was scared how far over i had the bike leaned in the twisties... he thought i was nutz!
                79 xs11 standard
                8mm msd wires
                tkat fork brace...
                Fox shocks...
                led's gallore...
                renthal bars
                vmax tensioner
                Rifle fairing
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  Spitfire S11
                  I found the Spitfire rear wore quickly but I may have got 10,000 kms on it before I changed it .Quite worn in the middle . I expected the Avon Roadrunner to wear as fast but am pleasantly surprised as I have 5000 + kms on it and it is hardly worn at all .
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  Iridium plugs w/ 1k caps
                  MikesXS front master
                  Loud Horns (Stebel/Fiamm)
                  Progressive fork springs
                  CIBIE headlight reflector
                  YICS Eliminator
                  • 81xsproject
                    • 3185
                    • Fortuna, CA
                    I don't think I have ever gotten more than 3k out of a rear tire. I thought it was just the cheap tires I used to run, but my Metzy lasertech's aren't doing too much better. On the other hand, I mainly ride locally and ALWAYS ride hard (and have BIG chicken-strips).
                    '81 XS1100 SH
                    Sep. 12th 2015
                    RIP
                      Hi yamahansolo,
                      From your above post you are just using them up.
                      If you want good tire life move to some state with flat straight boring roads or come up here where we only get to ride 1/2 the year:
                      Take a run up 129 for me before the cords are showing
