interchangable parts
  • rickdill1
    • May 2003
    • 3
    • Houston, Tx
    I have a 82 750xj parts bike. I want to take the forks off and put them on my 1100xj. It looks like they will bolt right up. Would it be unsafe to do this?
    rickdill1
    Houston, Tx
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    The forks on the smaller bikes are not as strong as those on the 1100 and have smaller brakes. You might be able to use them in a pinch but I wouldn't recomend it.
    Geezer
    • fusionking
      • Feb 2003
      • 453
      • lake of the ozarks MO
      I can't vouch for the XJ series but I Know that Most brake parts on XS750-XS850-XS1100 are the same. BTDT. Garry
      Garry
      '79 SF "Battle Cat"
      outbackweld@charter.net
      • Geezer
        • May 2003
        • 2985
        I know for certain that the XS11 has larger disk brake rotors than the 750 or 850. I'm pretty sure the rest of the brakes are larger also. I think only the disk pads interchage.
        I also know for certain that the 920 Virago used 1 XS11 Sepcial front disk and caliper. I find it dificult to believe that the XS750 had more brakes than the XV920.
        Geezer
        • fusionking
          • Feb 2003
          • 453
          You could be right dude never measured the diameter, just looked the same to me but I did swap master cyl. internals and they were the same and I was counting on my XS 850 rotors fitting my 1100 so I'll still be checkin' ya out on that one! Garry
          Garry
          '79 SF "Battle Cat"
          • Geezer
            • May 2003
            • 2985
            I didn't think about the master cylinder when I talked about the differences. I would have been surprised if the master cylinder was different. The calipers might be the same, but positioned further from the center of the wheel. When I compared one of my XS11’s to the XS750 my buddy had, the larger rotors couldn’t be missed. I think the XS11 rotors are thicker too. At least I know for certain that the rear one is. When we were changing tires I got a chance to put the rear wheels side by side.
            One of my parts bikes came with an 18” XS750 rear wheel on it so I can say with first hand knowledge that the rear wheels will swap out. I doubt there’s room for the wider 17” XS11 wheel on the 750.
