Another gas tank question
  • RidetoXS
    • 19
    • Elkhorn, Wi
    What's the best way to seal up the holes in the tank (fuel sender, petcocks) when prepping it for cleaning?
    1978 XS 1100 E Full Dress
    Patiently waiting to be restored back to life!
  • greatnw
    • 177
    I used an old inner tube to make rubber gaskets (very crude) and electrical plates with holes drilled in the appropriate places. Worked great. When I coated the tank I just used duct tape.
    Good luck to you. Be gentle with the process.
    Bothell, WA
    1980 XS1100SG
    • latexeses
      • Jun 2008
      • 1491
      • California
      When I covered the holes I used some 1/4" plexiglass scrap and pieces of an old truck tube for a gaskets.
      Everything on hold...
        • 5069
        Turn the sending unit so that the float is on the outside and use innertube as a gasket. You can use a piece of flatstock and drill holes for the bolts for each of the petcock holes.
