which grade oil? 'first' oil change
  • kevxs
    • Apr 2009
    • 353
    • toronto
    hey guys just picked up an oil filter from car quest it says 89933 on the box, hopefully this is correct. Which grade oil should I be putting in? The manual says 10 30 or 20 40, i'm thinking 20w40 should be good? I'll need 3.5litres right?
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
  • Bigge_al
    • Jul 2008
    • 98
    • Pleasant Garden, North Carolina
    Yes to both the amount and weight of oil
    Eric (South of Greensboro, NC)
    82 XJ1100 "Echos" Mostly Stock
    Matthew 4:19 "Follow me and I will make you fishers of men"
      20w40 should be ok in the heat of summer, but as it gets cooler, you may want to drop to a slightly thinner viscosity. However, since you probably won't be riding in the winter up there in the arctic, you may not have to worry about it.
      Make sure you change the middle and rear drive oils as well, if you have not already done so. Those both take 90w synthetic gear oil.
        OMG!!!
        I am just SO proud of you fine gentlemen!! Normally clamboring all over each other to state a prefered oil brand.
        Congratulations guys! *Applause*
        I will state though, that you can do a search for oil and find many happy hours of reading.
        • kirmit77
          • Mar 2009
          • 464
          • Kingwood, TX
          Touchy subjects like oil, politics or anything that might cause a controversy, you can def find HOURS of reading. More to read here than at school... right?
          Originally posted by trbig
          OMG!!!
          Austin Ingalls
          MIDNIGHT FURY
          1979 XS1100 Special [Full Restore Project]
          XJ maxim rear air shocks
          KERKER 4-into-1 exhaust
          Pod Filters
          Money pit.......
          BLACKED OUT
          • bobber
            • Dec 2008
            • 82
            • los olivos. ca
            i just changed to summer oil. as its gettin hot here.20/50 and she's shiftin smoother.you can deffently feel the differance.
            1978e. special forks.she's a frankinstien.a bit of this a bit of that.its a monster
            • kevxs
              • Apr 2009
              • 353
              • toronto
              Arg
              can't find 20/40, should I use 10/30 or 20/50?
              Green Dyna Coils
              1973 CB100
              kevXS
                • 3193
                I used to use the 10-30 all the time here in sunny Alberta but this year have gone to the 20-50 and am pleased with the results. less noise etc. I would not use it in fall or spring around here though as the temps are a bit colder then.
                • hamjam
                  • 1003
                  • Toronto ontario Canada
                  Hi
                  10 40 or rotella 15 40
                  Jim in Scarberia
                  Seamus Ó hUrmholtaigh
                  Niimi Moozhwaagan
                  NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
                  Any connection between your reality and mine is purely coincidental.
                  Member of "FOXS-11" (Former Owner of XS-11)
                  and SOXS
                  2008 Nomad "Deja Buick'
                  • yamahansolo
                    • Aug 2007
                    • 1113
                    • jawga
                    just switched to rotella 15w-40 and it seems great so far... a guy in fla said he only uses lucas in his ninja??? never tried it though. i used to sell amsoil and the tests on it are incredible compared to other oils. you can research it on the net. also read about the ballbearing test they do with oil. it's pretty interesting.
                    79 xs11 standard
                    8mm msd wires
                    tkat fork brace...
                    Fox shocks...
                    mikes650 front fender
                    led's gallore...
                    renthal bars
                    gold valve emulators
                    vmax tensioner
                    Rifle fairing
