Removing Pins from Electrical Connectors
  • newc4
    • 643
    • Vienna VA
    Can the male and female pins be removed from the connector blocks non-destructively. I assume there's some simple way of doing it.
    I've some corroded wires/pins that need replacing.
    Darrell
    Darrell
    78E
    80G project
    06FJR
    I assume there's a proper tool for doing so, but if you look to the front side of the pin where they are sticking through the connector, a small jewelers screwdriver or sometimes a thick paper clip can be inserted to lif up on the little retaining piece, It's a small thin piece of brass that curves down and catches on an edge of the plug when trying to pull back on it. You raise that little tab up then pull on the wire.. and it SHOULD come out. Corrosion can be a PITA though.
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      Yes they can. A Molex pin removal tool should do the job.
      1980 XS 1100SG
      Dyna 3 Ohm Hi Output Coils
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • ScottsXS
        • Sep 2005
        • 169
        • Demotte, IN
        i have the tool....used to repair hottubs, most of the old tubs have those connectors.you can buy the tool at radio shack
        when in doubt...get a bigger hammer
        '78 XS11e, '79 XS11sf,'81 Mazda RX7, '83 XJ650lj Turbo, '95 Ford F150, '93 Chevy K2500, '04 Honda Pilot,
        '89 Arctic Cat Wildcat, '89 Arctic Cat El Tigre 530, '81 Arctic Cat Trailcat 340, '79 john deere trailfire 440,
        '78 Cadillac Seville
        Don't steal the government hates competition
        • Jerry
          XS & TRUE XJ GURU
          • 3023
          • Elma, IA.
          Here is another thread that addressed a similar issue:
          Might be worth a look.
          Jerry Fields
          '82 XJ 'Sojourn'
          '06 Concours
          My Galleries Page.
          My Blog Page.
          • Geezer
            • May 2003
            • 2985
            • Willamina, Oregon 97229
            There's some info about that here.
            Geezer
            • b.walker5
              • Feb 2009
              • 1745
              • Invercargill, New Zealand
              If theyre the flat spade connector type then Tod's method is as good as any, and if you have round type connectors then the Molex tool is required as stated by MrOzz. It can be got here...http://www.jab-tech.com/Male-and-Fem...l-pr-2375.html
                They sell it at Radio Shack too. Under $10.
