After a month or two of work (and two or three carb teardowns, with at least one more in the future), I can at least delude myself into thinking my bike is almost ready to hit the road. The only problem with THIS is that most of my attention has been focused on the carbs, with not so much of it focused on the rest of the bike. Recently, say about yesterday, I got to thinking about what else needs to be addressed on my XS.
The few times I've rolled it around the barn (with help), it was always really hesitant to go anywhere. This didn't matter if it was in neutral or the clutch was pulled in- either way it was quite stubborn. At first I thought this was simply because it was such a big, heavy bike. Looking at it today, however, I'm not so sure.
You see, I would imagine that with the bike up on the center stand with the rear wheel off the ground and the tranny in neutral, you should be able to spin the rear wheel by hand. Alas, on mine you can't. So, to rule out the transmission, I squeezed the clutch and tried again. Again, solid as a rock. Finally, I turned the bike on, (CAREFULLY) put it into first (double-checking to be sure the wheel wasn't contacting anything on the ground) and let the clutch out just enough to get the back tire to spin, which it did. After I squeezed the clutch back in again, the rear wheel immediately stopped spinning.
My first instinct is that I have a rear brake sticking. I have yet to ride my bike at all (just finished my Motorcycle Safety Course yesterday, and I wasn't going to even try to ride it before I took the course), which is probably why it took me so long to find out. Is this what it probably is, or does this sound more like a problem somewhere in the drivetrain?
If it IS the brake, how hard are those things to get into and lubricate?
