Need help with ID of my XS1100
  • Filter
  • #16
    From one of your pics it looks as though the tank is riding against the frame. Are you missing the tank rubbers under the front of the tank?
    Looks like the po traded out the handlebars too.
    Everything on hold...
    • #17
      I didn't have the tank rubbers in for the picture but I do have them. The damage the tank did to the reflector mounts looks like they took a grinder to it so it would fit.
      Is there a way to may the standard tank fit right without destroying the reflector mounts if I replace them? Or should I just grind the mounts off if I use this tank?
      • #18
        That's a tough question ...
        When I put a Standard tank on my Special, I didn't encounter that problem cuz it was an early Special which has the reflectors on the sides of the 'fork brace' (with the Yamaha name on it) below the headlight and not on the down tube like the late Special has. Grinding it off will, of course, be the end of that mount once and for all ... but that is the only way I can think of.
        Also, I don't think we've mentioned that if you want the low fuel light on the dash to work, you'll need to swap the Std tank sender for one from a Spcl. too. FYI, I had the tank swap all done and running and then swapped it all back cuz I just couldn't get used to the uneven seat/tank match up. lol. Too much time on my hands and too many 11s, I guess.
        80G Mini-bagger
        Past XS11s
        • #19
          Originally posted by LRCXed View Post
          I read up on all the carb related post here and saw that the main jets in the carb's should be 120 and 115 on (I think) the outside carb's. Mine had 120's in all of them. Is that going to be a problem?
          Not a problem at all. The OEM setup had the internal carbs set to run their cylinders a little lean so as to not have them run as hot as the outside cylinders (air flow issues). Generally speaking, we all tend to make them teh same all the way across, for simplicity's sake. No visible effect on performance has been reported AFAIK.
          Glad you got the ID on you bike figured out. It seems common for people to erroneously sell these bikes as "Midnight Specials" to get more money for them. You've definitely got an '80 Special (SG) with a standard tank. If you're comfortable making your own seat cover, have at it. Otherwise, the covers aere available from several locations, and they just go right over the top of the existing foam, usually with a thin layer of foam on the inside of the cover to smooth out any imperfections.
          • #20
            Thanks Ford,
            I really appreciate the help you all have given me on this project. I didn't want to restore this bike with any unknown issues or misguided intentions. I know these bikes are well sought after if they are done properly. That's my intentions.
            I'll look at the options with the seat cover when I get the bike running properly. Thanks for the heads up.
            I'm glad to know the jets won't be an issue either.
            • #21
              Well, actually ....
              I think it is the opposite, Bug. Inner cyls were set richer to run cooler. Leaner is hotter.
              Having said that though ... 120s all across should be fine.
              80G Mini-bagger
              Past XS11s
              • #22
                I have an 81 model with 110s straight across and it runs great.
                • #23
                  Well, I didn't win the diaphragm assembly. I guess I need the help of someone here for a used one now. Anyone have a spare I can get????
                  • #24
                    here's one ...
                    scroll down the page ... https://www.partsnmore.com/cat_index...&category=carb
                    80G Mini-bagger
                    Past XS11s
                    • #25
                      Sorry 'bout that... Lean, rich, I get it all confused in my head.
                      • #26
                        '81 Carbs
                        Had 120 mains on the Standards as these carbs had a different size needle than the same year Specials.......just an FYI.
                        • #27
                          correction
                          My bad.........81 Standards had 110 mains as the metering rods were a different size than on the 81 Specials.
                          • #28
                            Hi LRCXed,
                            if you are ever going to be more than 90 miles from a gas station you will need a Standard gas tank. The reflector tags themselves will clear the tank so leave them, just remove the reflectors and carefully save them in case you decide to let aesthetics over-rule practicality and fit a Special tank. Put amber reflector tape on the frame downtubes to keep the safety inspectors happy.
                            The search function will find the details of how (and why) to fit the Special's thermistor fuel sender into the Standard tank and how to crop off 5/8" from the front of the Special's seat pan so it will still fit.
                            BTW, if you don't have a key for the Standard tank's gas cap you are deep in the soft & brown. The Special's raised fuel cap can be "sprung" quite easily by pressing down on it and poking a thin screwdriver in from the front to push the latch open. OTOH the Standard's elegant flush-mounted gas cap can't be got at like that. You will have to drill the lock.
                            • #29
                              Unfortunately I don't have a key for the tank lock. I was hoping the #'s stamped on the top of the lock would be the key code. I have had a few locks keyed that way. Are these #'s the key code?
                              I think keeping this tank on is a good idea. I'll take the reflectors off as you mentioned. What kind of MPG do these bikes average?
                              • #30
                                MPG's and mods
                                http://www.xs11.com/forum/showthread.php?t=18903
                                '79 XS11 F
                                Stock except K&N
                                '79 XS11 SF
                                Stock, no title.
                                '84 Chevy K-10 "Big Blue"
