Recently I got a 79 special on the cheap that had been sitting for almost 6 years. As you all can imagine the catbs need to be cleaned and rebuilt. As part of the rebuild I was going to eliminate the airbox and go with pod filters.
The issue is on the special there are two lines running into the airbox from the carbs that seem to have little metal rods attached to the end. When going to the pod filters what do you do with these. Also, this whole octy thing, never seen that before and it seems to look overely complicated. Is there a way that it can be eliminated.
Petcocks need to be rebuilt so I may switch to a more traditional petcock (on, off, reserve). Thanks
Sanders
Sanders
