No spark but will crank
  • MAX
    • May 2009
    • 9
    • lockwood
    I have a 78 xs1100e yamaha. I have trimmed back the spark wires also jumped the run button wires. Have replaced the tci box with gm ign. modules. I have crank no spark when holding the spark plug next to the case. I need alot help. thanks max
  • thewiz
    • Oct 2006
    • 1115
    • Wilksboro, NC
    Oh, geez ...
    This worries me .... can you still see the four wires that are W/g, W/r, Y/g and Y/r that were in the four wire plug at the TCI? If so, check for approx. 720 ohms between the two whites and the two yellows. If open, the ign. coils won't fire.
    If you can still put a TCI back in place, if I were you, I'd consider doing that. Replacements are pretty cheap .... I have a couple of extra.
    80G Mini-bagger
    Past XS11s
    • tw1980
      • Apr 2009
      • 662
      • Bend OR
      Hey Max turn on the ign key and check to see if you have power to the coils.You may have a connection problem.It looks to me like they get power threw the resister when running and from the stater circuit when cranking.If you have 12 volts at the coil primary's and you've tried the tci then check your pickup wires to the tci and all your plug connections.Terry
      1980 special (Phyllis)
      • MAX
        • May 2009
        • 9
        • lockwood
        Big thanks from max
        Thank you all for the help xs11 running because of all your input. Found a pinch wire in the pick coil. Thanks !!!!!!!!!!!
          • 2117
          I would like to see what that set-up looks like.Thanks
          • xs11bobber
            • Jun 2009
            • 229
            • Cromwell, Indiana
            I'm having this same problem with Pop's E. I've had it running 3 different times and then suddenly nothing again. I tested the caps with my ohm meter and it says they're getting juice. I can't remember how many ohms it read, it was 3 days ago. Should I go over the connections? Any in particular?
            (Sorry if it seems like I'm hijacking this thread)
            Josh Yoquelet -- I'm having dreams of my XS
            '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
            '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
            '81 Air forks w/23,000 miles
            New steering head races and bearings
            '78/'79 standard wire harness
            Drag bars, w/Mikes controls
            T.C.'s fuse block
            PNM Coils
            7mm Dyna Wires
            NGK Resistor Caps
            Custom 1" clutch and 9/16" MC
            http://xs11bobber.tripod.com
            • thewiz
              • Oct 2006
              • 1115
              • Wilksboro, NC
              Hey, bobber ...
              your everywhere, aren't ya'? Get them smooth bores yet?
              Although pick up coil wire failures are some of the most common problems found on the XS11 as these bikes have gotten older, they are still often missed and misdiag'd by owners and mechanics alike.
              Several members have good write ups at the link to the TECH TIPS below ... dust off your multimeter and check 'em out
              80G Mini-bagger
              Past XS11s
              • xs11bobber
                • Jun 2009
                • 229
                • Cromwell, Indiana
                ...truely xsive
                haha wiz, yeah. I've been living, breathing, and sleeping xs11's since my dad brought home a fixer upper. I bought one of my own and then I found this site and I'm probably on here 4-5 hours a day. I've learned so much already it's insane. At first, I was like "eh, a motorycycle. whatever." and that some how developed in to an obsession of these machines. I've also gained the confidence to do a lot of things I would've never attempted before in fear of fubaring something up because of reading so much about it... like the head bearings. It's a pain in the a$$, but not so bad since I had nearly 100% of the idea from this site. As far as those carbs, I'm deffintely going to get those smooth bores someday, but until then I'm working with the CV's. My dad always tells me when I dream I dream in color. And I always reply with, "I don't dream in color. I dream in high definition 1080p."
                As far as tech tips... I've read almost all of them, lol
                T.C.'s fuse block
                PNM Coils
                7mm Dyna Wires
                NGK Resistor Caps
