how to rmv odom knob
  • redbone
    • Oct 2007
    • 244
    • Waynesboro pa
    one member needs an odometer knob. i have just rmvd a broken speedo with a good odom knob and tried to pull and twist it out but got notta. i dont want to break it removing it. any one know how to get them out in one piece??
    any help appreciated
    redbone
    testing 1-2-3
    1980 1100 mns
    The Knob mam....just the knob.
    If you are only looking to remove the knob, it may help that it is a left handed thread.
      Hi Redbone,
      Like DGXSER sez, it's a LEFT hand thread. You gotta screw it on to screw it off.
      As it's most likely been there for over 20 years it could be a bit stuck.
      Take the outer case off so you can grip the stalk it's threaded onto with a pair of needle-nose pliers as you unscrew the knob.
      • redbone
        • Oct 2007
        • 244
        • Waynesboro pa
        i understand but...
        i am not here to kick a dead horse,but....while those are good ideas. not happenin.
        thanks
        redbone
        testing 1-2-3
        1980 1100 mns
        • XSPastor
          • Oct 2007
          • 602
          • Gaithersburg, MD
          Mine screwed right off. Left hand threads, of course. Maybe yours is just stuck?
          Tim Ripley - Gaithersburg, MD
          23mm float height
          120 main jets
          42.5 pilot jets
          drilled stock airbox with K&N
          Jardine 4 to 1 Exhaust
          spade fusebox
          1st and 2nd gear fix
          • Cobia
            • Jul 2007
            • 1587
            • Palm Beach County, Fl
            Try spraying it, soaking it, in PB Blaster. Thay stuff does the trick on just about anything.
            1980G Standard, Restored
            Kerker 4 - 1
            850 Rear End Mod
            Automatic CCT
            1980GH Special, Restored
            '82 XJ1100 (Sold)
