Well, Griz ...
I'm not real sure how to interpret the latest comp test numbers ... 'specially since I'm not there to watch the guage as it pumps up.
Also, I have never had a dead hole on any of the XS11's motors that I have ever worked on (knock on wood) ... so I'm not completely sure that what you're reporting actually indicates a bent valve in #1. If it were 60 psi instead of 120psi, it would be a no-brainer ... bent valve.
Maybe someone, and there are more than a few on here, who has had a bent valve can jump in here and report if the reading in #1 is low enough to indicate a bent valve. If no one does, I would Top Dead #1 on it's compression stroke and take my blow tip and stick it in the plug hole. The blow tip would seal up the cylinder and then I would squirt some air in there and listen for air leaking out into the intake or exhaust. If I couldn't hear anything, I would beg, buy or borrow a cylinder leak-down guage and that would tell the tale.
