Cutting down a windshield
    Ken,
    That was a great "How To". Really brought the process into my home. (So much so that I almost reached for my safety glasses while you were doing the sawing.)
    Video was a nice touch. Thanks!
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      Originally posted by Ken Talbot
      I finally got around to cutting down the 21" tall windshield on Tsunami today. Having ridden SWMBO's Purple Reign with its 18" windshield, that seemed like a good height to go with, allowing me to see over the top edge, but still having the main airstream pass over above the top of my helmet. Lots of pictures and vid clips to follow:
      First, tape up the windshield with lots of wide masking tape. Mark the new height in the centre. Clamp a 1/8" dowel to produce a nice curve parallel to the top edge, and use this to mark on the tape with a sharpie.
      Hold a bit of cardboard behind each top corner to make a template for the new lower corner shape.
      Trim the templates, and transfer the new corner shapes for each side.
      Use a jigsaw with a sharp, coarse blade.
      Run the saw on a very slow speed to prevent heat build-up which can cause the chips to melt and fuse into the kerf behind the blade. On my Dewalt, I set the speed to just a bit above 1.
      Take your time with the cutting, letting the blade do the work. The more care you take in keeping to your line, the less time you will have to spend later cleaning up the edge.
      Once you've cut about half way, stop. Tape up the kerf so as you get to the other side, the cut will not fall off.
      Here's what the raw cut edge will look like.
      Now, here come the videos! First is a shot of cutting. Nice and slow...
      Once cut, start refining the edge with a coarse file. I like to use a file made specifically for aluminum.
      Next use a power sander with 80 grit paper.
      320 grit paper comes next, in a handheld rubber sanding block.
      Wet or dry paper in 400 grit, used with water is next.
      Final sanding is done with a polyester-backed ultra fine sheet that is made for polishing plastic. Also used with water.
      This special polyester-backed abrasive comes in a kit.
      Remove the masking tape.
      And finally, get out your favourite celaning product and clean the new, shorter windshield.
      Here's how the edge turned out.
      It's as easy as that!
      nice work, once i cut one too far and the buffeting was horrible, could of used a laminar
      This website is for sale! shooterforums.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, shooterforums.com has it all. We hope you find what you are searching for!
      but didn't know about it until i saw maximan's ride, that he sold for the zx14 or rather concourse...
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
