Choke lever breaking off
  • CatatonicBug
    • 6117
    • Clinton, UT
    I just discovered that my choke lever handle is just about to fall off. In researching for a replacement, I have discovered a few things that I need clarification on.
    1. My lever is NOT black. However, as is mentioned in another thread, as well as the image from benefiscal (below), the lever on the MNS is supposed to be black. Is that true?
    2. The image above shows the replacement part is straight. Mine (below) is bent over. Is it supposed to be bent? Is that just something you are supposed to do after installation, or is it supposed to remain straight? Mine is breaking right at the bend, so I am concerned about the proper installation of whatever part I manage to find to replace this one.
  • thewiz
    • Oct 2006
    • 1115
    • Wilksboro, NC
    S'posed to be ...
    straight ... not bent 90 degrees like the photo.
    80G Mini-bagger
    Past XS11s
      Hi 'Bug,
      black is available everywhere inside rattlecans.
      And no, yours should be straight up. Seems like some genius bent yours over by pounding it over in a vise and the sharp 90º bend is starting to fail.
      You can mend it. Remove the lever, pull the plastic knob off and re-weld the 90º bend if you like it like that or pound the lever flat again (the bend will most likely break completely if you do) and re-weld the two pieces back in the original position. Fizz it black, slide the knob back on and you have what will pass for a NOS Midnight Special lever.
        Hey Bug,
        This is one of the few underengineered parts on the XS11! They get bent because folks would not keep the choke lever/rod properly lubed, and they get corroded and stiff, stick, and harder to pull out, hence the bending of the lever/handle! Other suggestions have been to take the choke rod, tap some threads on the end of it, and then attach a drawer pull knob or such onto the end.
        I fabricated a replacement out of an outdoor door hinge! But if you have welding capabilties, then that would be an easy fix, and the black paint along with a grinder will hide the cosmetic imperfections!
          • 8893
          Another option, as TC mentioned....
          • Lamric
            XStremely XSive(Deceased)
            • 410
            • Kenley, Surrey, England
            ....the lever on the MNS is supposed to be black. Is that true?
            Yep, the choke lever on both models of Midnight (LG & LH) is black.
            The good news is that these are shown as still available from CMS - a Yamaha parts dealer in the Netherlands. They have an odd parts numbering format so use part number 4H31497500
            You can link there from the part details page you got the picture from (just scroll down to the section "Possible Suppliers").
            Brian
            • redbone
              • Oct 2007
              • 244
              • Waynesboro pa
              yep
              yes, they are notoriously junk. mine is also broke. just learned to deal with it. someday maybe i'll get a new one.
              testing 1-2-3
              1980 1100 mns
              • CatatonicBug
                • 6117
                • Clinton, UT
                Thanks! They are asking $37.63 (27 euros). I may get one eventually, but I'll probably get mine welded for now.
                • CatatonicBug
                  • 6117
                  • Clinton, UT
                  Well, I found a choke lever at my local bike junkyard, and literally got attacked by the junkyard dog in the process! I'm glad I had my armoured riding jacket on, because the dog went straight for my arm as soon as I stepped behind the counter to follow the guy back to the only XS they had.
                  They have a '79 std, and it's a bit torn apart, but it still has the carbs on it. The choke lever was even there too! It looks a bit different from the one on my '81 MNS, but it fits!
                  For $15, I figured it was worth it. It started out a bit rusty:
                  And after 20 minutes of soaking in rust remover, here is what it looks like now:
                  I'll probably hit it with rust remover one more time, just to shine it up a bit more. My choke is a bit stiff (the reason the lever started to break in the first place) so I might take some time this weekend and try to clean that out. I might also try to get my current choke lever welded, but then again, maybe I won't...
                  • thewiz
                    • Oct 2006
                    • 1115
                    • Wilksboro, NC
                    Good score at the boneyard ...
                    and good idea to lube up that enrichener rod. I've seen a bunch of racks of carbs with 'em broken off and missing altogether.
                    Send it up to Rob, and he can weld in some gussets on there to stiffen it up some .... and then maybe chrome or powder coat it !! Just kiddin' ... would be cool though.
                    80G Mini-bagger
                    Past XS11s
                    • rpgoerlich
                      • Dec 2007
                      • 643
                      • Katy, Tx
                      Mine broke as well on the XS11SF. I pulled it off and welded it back together, ground it down, shot it with a coat of silver paint. Works just fine.
                      Richard
