axle too short?
  • geniusloerts
    • Jul 2007
    • 420
    • fayetteville, Arkansas
    axle too short?
    here is one for all of you......
    on my brothers xs the real axle bolt is not long enough to place the cotter pin through the castle nut. i tried my extra axle out of my other xs SF from 79 but it was the same length.......his xs is a '80 standard
    any ideas?????
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
    A washer too many?
    Originally posted by geniusloerts
    here is one for all of you...... on my brothers xs the real axle bolt is not long enough to place the cotter pin through the castle nut. i tried my extra axle out of my other xs SF from 79 but it was the same length.......his xs is a '80 standard - - - any ideas?????
    Hi geniusloerts,
    was it always too short or did it suddenly become so at the last tire change?
    The one says "wrong part" and the other says "assembly error".
    • geniusloerts
      • Jul 2007
      • 420
      it has always been too short in the 2 years i have known the bike.....and since he has had it. its almost like the swing arm has been spread apart.....
      is there a diffrence between standard and special axle shafts?
      -Pod Filters
      -4-1 pipe
      • randy
        • Dec 2003
        • 4521
        IIRC, the axles are the same. Even if the swing arm has been 'spread apart', the axle fits inside the swingarm pinch area (right side), so it should line up on the cotter side (left). Are you sure you've got it torqued down properly? Has the P.O. used the correct wheel bearing on the left? JAT.
        • geniusloerts
          • Jul 2007
          • 420
          its torqued properly...... the only thing i can think of is a wrong spacer.....but the only diffrence is one and its less than 1/8" difference
          -Pod Filters
          -4-1 pipe
          • geniusloerts
            • Jul 2007
            • 420
            on my brothers from the inside of the swing are on the right side to the calaper housing braket is .68"
            on my spare 79 is .32"
            -Pod Filters
            -4-1 pipe
            • geniusloerts
              • Jul 2007
              • 420
              well i fixed it.......it turns out that there was a spacer in there that was not supose to be.....it was one off of the front wheel of another bike...so i donated my caliper bracket off my spare bike and voola he notw has a pin to keep the back end from falling apart
              -Pod Filters
              -4-1 pipe
                Any luck on finding another motor for your bike?
                • geniusloerts
                  • Jul 2007
                  • 420
                  head in the sand Tod?
                  where have you beem man? did you not catch the last post on the "sad day and a tear shed" thread............
                  its in its going and I have all the parts to fix the other motor as a back up or its going in my brothers bike, then i will rebuild his to hang on to.
                  -Pod Filters
                  -4-1 pipe
