fluid levels or cancer?
  • greg maz
    • Feb 2008
    • 219
    • Arlington Heights, CA
    and that's precisely why I began to itch: I have bad memories of working on honda and bye bye threads
    plus I am pissed at autozone for not honoring their "life warranty" shocks I got for the van, kragen and a torque wrench then, and up side down it goes
    82 XJ1100 Klonk= SOLD
    No longer active member.
    • COOL TOM
      • Jul 2005
      • 288
      • CANTON, IL
      Auto Zone
      greg max go to Auto Zone and talk to the manager of the store about the warranty on your shocks. If he will not help you tell him you want the name and phone number of the district manager, get the names of the people you talked to in the store and tell him how they give you the run around. If he will not help you ask for the name and phone number of the regional manager. I will bet you get your shocks replaced by the store manager.
      Thanks Tom
      82 XJ DAILY RIDE
      78 XS1100E FIXING UP
      79 XS1100F PARTS BIKE
      79 XS1100SF NAKED BIKE
      80 XS1100SG FULL DRESS BIKE
      82 XJ IN THE ROUGH
      • Bigfoot
        XS-XJ GURU
        • Sep 2005
        • 1422
        • Kansas City, Missouri
        Unless I am mistaken, the one place that a torque is needed is when re-installing the clutch. Not only that bit I think it was something like 7 inch lbs of torque. I picked up a 1/4 inch drive small torque wrench at harbour freight pretty cheap. I don't think that is a part I would want to estimate when installing. Also, the grinding should not take all that long. With a cut-off wheel to do the dogs, I think I had it done in around 15 minutes the last time I did it.
        Harry
        '79 Standard
        '82 XJ1100
        '84 FJ1100
        Acta Non Verba
        • greg maz
          • Feb 2008
          • 219
          it keeps getting better, 15mn who says faster?
          thanks every one for the lowdown
          as for autozone, I talked to the district manager after a few days (van stranded in the meantime) and "the shocks are under lifetime warranty now, but when you bought them they were under 2 years warranty...". Doesn't make sense since I bought them for that precise lifetime warranty. All maintenance on the chevy was autozone, they lost my business.
            • 7795
            If you go to Kragens, get "The Right Stuff" for gasket material! It's not cheap, about $15 for a can that will do the bike 1.5 times, but it works. I've been using it on the valve covers of the bikes I work on, and do NOT have any leaks. It's easy to use, as you only need one side oil free. I clean the cover, and apply it to that, let it set for about 15 minutes and install.
            • greg maz
              • Feb 2008
              • 219
              boiled down recipe for gear fix?
              guts
              1 kragen
              1 leased torque wrench
              1 "right stuff" gasket for dummies $15
              1 dremel ($40) with $40 of head
              1 weekend
              watch replacement of spring ($?)
              do washer swap
              & reuse of oil?
              cool thx
              • greg maz
                • Feb 2008
                • 219
                Diver Ray
                what evidence do you hold?
                I'd like to ride down and meet you guys someday.
                • greg maz
                  • Feb 2008
                  • 219
                  if I reuse the oil the gears just chipped into I am doing damage,
                  so
                  addendum:
                  3 liters of 20w50 (with a splash of lucas gear oil) ($10)
                  1 liter middle & end drive gear oil ($10)
