New owner
  • tarzan
    • 1700
    • Chandler,Az.
    You can install that screw right there at the bike.Just put the washer on the screw then the o-ring then install the screw in the hole.
    I have bought those o-rings at a local bike shop.They need to be fuel grade.Auto parts store might have em.You will probably need an old one to match it up.Maybe just take the screw with you,they might be able to help you out that way.
    80 SG XS1100
    14 Victory Cross Country
    • tarzan
      • 1700
      • Chandler,Az.
      oops double post
      80 SG XS1100
      • Bronzeback
        • 14
        Here's what I'm looking at:
        • Bronzeback
          • 14
          and for reference the #4 carb:
          • Bronzeback
            • 14
            And the whole rack:
            • Bronzeback
              • 14
              And what the hell, here she is next to my riding parters steed:
              • tarzan
                • 1700
                • Chandler,Az.
                If the threads are ok in that hole,just screw in the new screw with 0-ring and washer of course.
                Those carbs dont generally break the screw point.So you should be good too go.
                80 SG XS1100
                • Bronzeback
                  • 14
                  Originally posted by boyat68
                  BronzeBack:
                  This is an image of the parts that go into that Pilot Air Screw Tower.
                  ...so everything seen here, in that order?
                    • 8930
                    Put the spring on the screw first. Then the washer, then the O ring. Put that assembly down the tower and screw it in. Leave off the tamper-proof cap.
                    • John
                      • 5117
                      You will find sometimes that the washer and O ring will fall off if you try putting it all 'down the hole' with the carbs in the upright position. Try positioning the 90 degrees so the screw can be inserted parallel to the bench top. Nothing can fall off the screw that way.
                      • Mr. Schweer
                        • Dec 2008
                        • 152
                        • Clovis, Ca
                        i would put a tiny dab of lithium grease on the assembly before dropping it in place with the carbs straight up.
                        '96 Kawasaki ZX11, bought February 5, 2015
                        '79 Kawasaki LTD 1000, bought Oct 19,2010.....sold Sept 12, 2013
                        '81 XS11 Special, bought May 6, 2010.....sold Oct 19,2010
                        '79 XS 11 Special, bought July 3rd, 2008
                        '78 XS11 Standard, bought July 2, 2009.....sold Aug 25, 2011
                        • Bronzeback
                          • 14
                          Ahh..grease would be a good idea. I went to the local Yamaha dealer and asked if they happened to have the o-ring I needed. After explaining what I needed dude brought out the tiny little thing. "How much?"..."Just get her running Man" he said...nice guy. Anyway o-ring fit like a glove, got the assembly in, found the other three turned out about 4 turns. Reset all to 3 turns out, re-synched, took her for a spin. Occasional backfires gone, running smoooooth. I like this bike!
