Fuel filter question
  • Lucien Harpress
    • May 2009
    • 213
    • Adrian, MI
    After a few incidents involving tearing apart my carbs three times and a can of Seafoam knocking off most of the rust from the inside of my gas tank, I thought it wise to install a few inline fuel filters before I put the carbs back on. Do I need any special type filter for this, or does it just need to fit the fuel lines?
    (The reason I ask is that my local Tractor Supply has some small $4 fuel filters I might get, but I figured I'd ask the experts before I do.)
    Currently XS-less.
  • 03mach1
    • 114
    • Cuba, NY
    Doesnt' hurt at all to have them, there are threads on here that show them slipped in between the carbs, kinda tight fit, but the smaller the better. Do a search on Fuel Filters...not a lot of room unless you have the air box removed and pod filters, you can use larger ones.
    here a good thread under the Mods/Maintenance section
    Dave
    • tarzan
      • 1700
      • Chandler,Az.
      Yep tractor,lawn mower,or motorcycle specific will work.
      Guys here have used all kinds.
      80 SG XS1100
      14 Victory Cross Country
      • Lucien Harpress
        • May 2009
        • 213
        • Adrian, MI
        http://www.xs11.com/forum/showthread.php?t=109
        That's actually quite a slick setup. I think I'm going to do a bit of shopping tomorrow..... Thanks for the help!
        Currently XS-less.
        • kevxs
          • Apr 2009
          • 353
          • toronto
          question?
          If I do this mod do I just keep my prime lines routed as they are now?
          1979 XS1100SF 37000km
          Green Dyna Coils
          Stainless Brake Lines
          1973 CB100
          kevXS
            You can just put a filter on those lines too.
              Or you can put the filters between the "T" at the prime and the carbs. Two filters to cover the carbs. Down side, no filter between the tank and the octy...
