Bargain - Carb Manifolds online
    I think the rubber provides a vibration isolation form the engine as well to some extent, and also a flexible seal to the carb body.
    • xs11bobber
      • Jun 2009
      • 229
      • Cromwell, Indiana
      I'm actually liking where this is heading. (Polished) aluminum carb boots with a rubber seal. Personally I think that'd be pretty sweet. Give that area a little more flash for the not always so great looking carbs. I'm going to be keeping up with this for sure.
      Josh Yoquelet -- I'm having dreams of my XS
      '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
      '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
      '81 Air forks w/23,000 miles
      New steering head races and bearings
      '78/'79 standard wire harness
      Drag bars, w/Mikes controls
      T.C.'s fuse block
      PNM Coils
      7mm Dyna Wires
      NGK Resistor Caps
      Custom 1" clutch and 9/16" MC
      http://xs11bobber.tripod.com
      • 81xsproject
        • 3185
        • Fortuna, CA
        I run my head temp sensor for my EFI on the rear most bolt of the valve cover. On moderate days, it sees temps around 220. I imagine it would be a little warmer down by the manifolds. Probably mid to high 200's.
        I think we need to start talking about this seriously, possibly in a new thread. Try to get a group order together, and see if any of our members across the pond would be willing to do a re-ship for us.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • res1uqtp
          • May 2009
          • 84
          • East Central IL
          I'm definately interested in a group order. I've got two xs1100 projects and both need a full set
          My Stable:
          2006 Triumph Bonneville Black
          1979 Yamaha XS11 Special (2 of them)
          1982 Yamaha XS400 Heritage Special
          1981 Suzuki GS550 E
          1976 Honda CB550F Supersport
          • MindWebs
            • May 2009
            • 431
            • Baldwin, WI
            yea, to get them at that much of a discount i would be intrested as well..
            mine aren't preaty but i'd like to be "sure" what condition they're in.
            new, fixes everything don't it?
            hee, hee
            Webs
            • xs11bobber
              • Jun 2009
              • 229
              • Cromwell, Indiana
              I'm going to need a set. I'm going to have another bike project ligned up right after this and it's going to need a set. And then it's always nice to have spares for those "just in case" situations.
              I'd still like to know the possibilities of an aluminum/steel "custom" carb boot though.
              Is there a way to take the rubber area that connects to the head and then fabricate a size specific mm tube with a rubber grommet at the end that will still hold the carbs?
              T.C.'s fuse block
              PNM Coils
              7mm Dyna Wires
              NGK Resistor Caps
                Has anyone ever taken a temperature of the intake side of the engine around the carb boots?
                Just with the back of my hand while trying to adjust the idle on a nice toasty warm motor. It is officially a good three cuss words hot more or less... depending on total exposure time to flesh.
                • petejw
                  • 2269
                  • sydney australia
                  I was reading on the uk site,
                  that some of the aftermarket inlet manifolds being sold arent
                  of the best quality, not saying these are the ones,
                  but just thought that id let you know.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  1981 xs1100 RH (aus) (5N5)
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                  • xs11bobber
                    • Jun 2009
                    • 229
                    • Cromwell, Indiana
                    After an extensive night of research, I've come across something a little different.
                    Anyone seen these yet?
                    T.C.'s fuse block
                    PNM Coils
                    7mm Dyna Wires
                    NGK Resistor Caps
                      Maybe many of the bikes out there are simply rubber boots, but ours are actually steel lined with rubber on both sides.
                      • MindWebs
                        • May 2009
                        • 431
                        • Baldwin, WI
                        i'm running a similar set of carb inlet and carb outlets like the TC bros set.
                        seem to work well.. (on my S1)
                        same as anything, make sure they seal to the engine.
                        Webs
                        • mn2346
                          • 101
                          • Shenzhen - China
                          Usually the price can be negotiated with a group purchase not much but maybe to cover the shipping charges?
                          Marko
                          '81 SH
                          • xs11bobber
                            • Jun 2009
                            • 229
                            • Cromwell, Indiana
                            It would help if they'd post the weight of just 1 set of carb holders. Then you know how many it's going to take you to hit their requirment. Anyone know how much a set of carb holders weighs? And then know how to convert it to kilos?
                            T.C.'s fuse block
                            PNM Coils
                            7mm Dyna Wires
                            NGK Resistor Caps
                            • Lamric
                              XStremely XSive(Deceased)
                              • 410
                              • Kenley, Surrey, England
                              A set of 4 TourMax carb-engine manifolds (plus gaskets, plus light card box they come in) weigh 560g.
                              Brian
                                That means 44 sets would be just under the 25 kilo limit.
