Hi All
I took the Bike out for a bit of a blast last night - may have slightly broken the speed limit a few times on my little ride too
However, I just noticed that there's a bit of oil on the final drive casing - I've included photo's here too - any idea what could be leaking around this area ? (I had a look and couldn't spot the exact leak) - there's no oil dripped onto the floor overnight, but I've found the thing about leaks is they get worse when you least expect it - that, and the oil probably only leaks out when the final drive heats up ?
I had a leaking diff on the trike, but that's got 2 wheels at the back and not so likely to leak oil onto the wheel !
Cheers
Chris
Cheers
Chris
