still won't fire
  • co1954
    • 9
    • Redfield, Kansas
    still won't fire
    Help! I've got a 82 xj1100 that dropped a valve,I replaced the motor with a 78 xs1100 but after installed it would'nt fire, so I replaced all the ingition parts plus the wiring harness from another xs1100, motor still won't fire, all the parts I got are good, got em from andress weiss and he knew they were alright, I'm stumped, done everything I can think of and out of ideas.
    You may already know all this, but if your still using the XJ brain box, it has ALL the advance built into it, so no mech or vac advance is used if I understand that beast correctly.
    Also, when you installed the pickup coils, did you verify which coil went to which pickup? If you get them swapped, the bike will not fire. DAMHIK You could try swapping the coil plugs up under the tank. It has been known to work.
    • boyat68
      • Oct 2007
      • 358
      • Virginia
      One other thing, check and double check that your kill switch is in the center position. Just a little bit to the right or left will not allow the bike to fire. Often this switch is bumped when doing maintenance on a bike and is easily overlooked.
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        more
        Anymore details on the year of the wiring harness and exactly what parts are from what years etc all the way from the timing assembly to the TCI and up to the coils . Are you using the Ballast resistor ? etc etc ... more details pls and pictures would help .
        XJ1100K
        Avon rubber
        MikesXS black coils
        Iridium plugs w/ 1k caps
        MikesXS front master
        Loud Horns (Stebel/Fiamm)
        Progressive fork springs
        CIBIE headlight reflector
        YICS Eliminator
